Problem with SoE servos AMK and DC
5 years 2 weeks ago #223398 by db1981
do you have an manufactures xml description for this drive?
5 years 2 weeks ago #223399 by rollfree
Yes I have.
But I didn't find anything inspiring in it.
Is in the attachment.
File Name: AMK_ECsoe_...6633.zip
File Size:8.53 KB
5 years 2 weeks ago #223402 by db1981
Do you set S-0-0001 and S-0-0002 at startup time to 0x03E8 (1000us Synctime) ?
5 years 2 weeks ago #223403 by rollfree
Yes, both have a value of 1000, that is 1ms.
5 years 1 week ago - 5 years 1 week ago #224204 by rollfree
Just information: under SOEM the problem is the same.
The integrated AMK motors simply have a problem with active DC.
But older models just don't run without DC.
Schizophrenic situation.
The best solution is probably not to have servos from AMK.
Last edit: 5 years 1 week ago by rollfree.
5 years 1 week ago #224217 by db1981
did you test with Twincat on the same pc?
We had often sync errors with AX5000 and Indradrives in the past. After installing
an Intel 1000 Pci-e card, everything works.....
Time to create page: 0.200 seconds
