So , now with more experiments and in the situation is , if drivers needs to move 5mm to find the reference , when the homing is done the driver will move to -5 after the homing ended , i dont know if that helps .
I think I have the same problem as you. Have you solved this problem now?
This is the description of the problem I encountered. Can you see if it is helpful
