I did some research and I found 2 things which might be the causing the problem:
1.
Enable notLRW: yes
I have gone through some post in forum and I came to a conclusion that because of the above problem, Drive required different domains for read/ write PIDs.
Unfortunately I could not find examples or docs to activate multiple domains on the master to fix my problems and I don't know how to proceed further if it is "the Problem"
is there a way I can set "
Enable notLRW" to
no?
I will attach a links to get a clear idea of above problem:
www.forum.linuxcnc.org/24-hal-components...pins-rw-doesn-t-work
2. My Kernel is "uname -a"
Linux linuxcnc 4.19.0-22-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.260-1 (2022-09-29) x86_64 GNU/Linux
is still 4.19.0 but I don't think it should give any problem.
if anyone has any advice/suggestion, please help me out
Regards
Abhishek
