Andy, With some knowledge of homing.c The combination of man homecomp and the source actually does give quite reasonable documentation in Dewey Garrett's precise and succint styleBut a neater way might be a custom .comp that senda a homing command to the drives, and then just waits,
You set up a custom homng routine uisng the [EMCMOT]HOMEMOD INI file setting. I haven't found any documentation of how to write the component, but there is an example file here: github.com/LinuxCNC/linuxcnc/blob/master...onents/homecomp.comp
