Leadshine EL8 configuration
2 years 10 months ago - 2 years 10 months ago #289211 by eduard
Hello community,
I've started to configure a new EL8 servo controller for LCNC Ethercat.
The drive and motor is up and running from Motion Studio 2, but not reaching OP state in LCNC. I'm very new in both LCNC and EtherCAT.
Status from Motion Studio: PDS: AxisA (1: Not ready To Switch On), ESM: AxisA (2: Pre-OP)
The motor was set to absolute encoder Pr0.15(1)
The manual has this part where describing this status:
I do not have any clue, what to do with. Appreciate some directions. Thanks.
Last edit: 2 years 10 months ago by eduard.
2 years 10 months ago #289255 by eduard
Replied by eduard on topic Leadshine EL8 configuration
Solved first problem to communicate with the servo. I have a bad address in pid:
<slave idx="3" type="generic" vid="00004321" pid="000010b2" configPdos="true">
after changing the pid value to pid="000010c2" the drive entering OP state and X axis starting to work from Qt dragon.
Now I have to fuguring out how to home with absolute encoder and without limit switches.
2 years 10 months ago #289289 by eduard
Meantime I solved homing and working great with absolute home mode. The LCNC receiving home state without moving.
But I need to calibrate the CNC (XYYZ) so I have to square the YY and manually write the encoder state. The drive has an oprion for this, here is the part of the manual:
Anyone has the knowledge how to:
1. enter the HM (6 mode)
2. set the encoder to the actual position
3. exit to CSP mode (8 mode)
2 years 9 months ago #290326 by buzzFab
Replied by buzzFab on topic Leadshine EL8 configuration
@eduard
I have the same drives but I haven't had anytime to set them up. I was working on it a few months back but had to put it on the back burner for a little while longer.. If you don't mind posting your files when you figure it out so when I get back to it I have something to work off?
I would be super grateful
Eric
2 years 9 months ago #290366 by eduard
Hello Eric,I have the drives configured for my needs. Here are the files for further review.
The following user(s) said Thank You: tommylight, buzzFab
2 years 9 months ago #290401 by buzzFab
eduard,
thanks a lot, I appreciate this as it will save me time for sure.
Eric
Time to create page: 0.191 seconds
