Hi, this is my first post. I've learned quite a bit from rodw, Hakan, and a bunch of other helpful posts.
I am trying to figure out the LinuxCNC part of a build that would use RS400E servo drives, an ECT86 closed loop stepper drive, and maybe an RTEC1616. I don't have the Rtelligent hardware, as I would like to figure out the LinuxCNC part first. I have a couple of questions, but I will start with the steps I have taken so far.
1) I installed rodw's image from this post and followed the instructions in the readme file
forum.linuxcnc.org/9-installing-linuxcnc...cnc-x86-only?start=0
2) The readme file took me to the bottom of the first post in this thread
forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
2a) I believe Ethercat is running. Here is a picture.
3) Then I followed these steps:cd ~/dev
git clone
github.com/dbraun1981/hal-cia402
cd hal-cia402
sudo halcompile --install cia402.comp
Which I tested with the following results
4) At this point, things started to go off the rails. I followed the instructions at the following link
github.com/rodw-au/linuxcnc-cia402/tree/main
And finished these instructions by installing the cia402 configuration with the following commands
cd ~/linuxcnc/configs
git clone
Open Linuxcnc and select cia402.hal
5) I opened LinuxCNC and chose the cia402 configuration, which led to the following error report (attached as linuxcnc1.txt)
6) I took a shot at fixing a problem by changing line 14 of cia402.hal from
loadusr -W ./lcec_conf ethercat-conf.xml
to
loadusr -W lcec_conf ethercat-conf.xml
which generated the following error report (attached as linuxcnc2.txt)
Questions: Before I spend big bucks on hardware, I'd like to get as ready as possible. I understand that the xml file will have to change to match the hardware, and I have drafted a new xml file for the RS400E servos. Are the errors I am seeing being caused by the lack of hardware? Is there anything else I can do (or fix) to get LinuxCNC ready for hardware?
Thanks again for everyone's help.
