Help,Leadshine DM556 open-loop stepper config
- timaer
- Thank you received: 4
20 May 2024 02:58 #300985
by timaer
Help,Leadshine DM556 open-loop stepper config was created by timaer
Hi,everyone,I'm a new diving to ethercat ,I want to config a machine using ethercat with 3 leadshine DM556 open-loop stepper. Is there anyone be very kind to offer me a sample code(including .ini,.hal,.xml stuffs) or link which can make the open-loop stepper works .Appreciate for any comments ,thanks
- jjdege
- Thank you received: 38
20 May 2024 20:21 #301030
by jjdege
Replied by jjdege on topic Help,Leadshine DM556 open-loop stepper config
HI
To use the DM556 open loop I think you need an Ethercat controller,
I know the FR400, there are probably other devices, I don't know.
On the manufacturer's website you can download a working configuration for LinuxCNC.
I'm working on a retrofit on the electronics of a small old machining center
the FR400 drives MOONS' SR4plus and DMA860S steppers, with EasyIO as in/out,
the mini center has an ATC and several in/outs are needed, otherwise the FR400 is sufficient for a traditional CNC,
everything works perfectly.
Hi
Hi
The following user(s) said Thank You: timaer
- timaer
21 May 2024 01:30 #301047
by timaer
Replied by timaer on topic Help,Leadshine DM556 open-loop stepper config
Hi,thank you so much .as what you described,it looks that I still need hardware to support to use the open-loop stepper,such as a ethercat controller .I think you are right .Even if I bought the ethercat controller,I still dont know how to config the specific device.So,to the software part,would you share me a sample code or some resource link that I can used for make the open-loop stepper work? I'll appreciate that,many thanks again !
- jjdege
21 May 2024 17:33 - 21 May 2024 17:37 #301093
by jjdege
HI
sorry which EtherCAT controller did you buy?
Last edit: 21 May 2024 17:37 by jjdege.
- timaer
22 May 2024 05:24 #301128
by timaer
Hi,according to the attachment file .I guess it's called DM3E-556 ?
- jjdege
22 May 2024 16:41 - 22 May 2024 16:41 #301155
by jjdege
HI
sorry but the DM3E-556 communicates directly via EtherCAT with LCNC,
what I said applies to the DM556 which needs an EtherCAT controller to communicate with LCNC
I don't see DM3E-556 among the devices supported by LCNC,
you will need to build an .XML generic to make it work
Last edit: 22 May 2024 16:41 by jjdege.
- timaer
23 May 2024 01:13 #301177
by timaer
Hi,I found some resources link in the following ethercat official doc github.com/linuxcnc-ethercat/linuxcnc-et...leadshine_stepper.md please check it .and I thought it mentioned the leadshine 556 ?
- jjdege
23 May 2024 07:21 #301183
by jjdege
HI
in the link you posted there is a reference to the Leadshine EM3E-556E model,
resembles DM3E-556
With an installation of LCNC, etherCAT and the cia402 component,
as fully described here by Rodw,
you can check if LCNC sees the DM3E-556 the same way
otherwise I think you have to work on the .XML file
here is the DM3E-556
resembles DM3E-556
- timaer
24 May 2024 01:52 #301272
by timaer
Hi,in the terminal ,while I used "ethercat sl" command ,it did show up connected to DM3E-556 but while I used the control panel such as axis ,it can't control the stepper motor to rotate.I guess the problem may be due to .ini or hal and xml file ,but I dont know how to config it correctly .I looks that it 's much more complex to config the open-loop stepper motor comparing with the servo motor.do you have any workable .ini/.hal/.xml file of the open-loop stepper motor ?
- jjdege
24 May 2024 07:18 #301291
by jjdege
LCNC starts?
if it starts in halpin lcec.0. your device with connection pins, are they visible?
Connected in "OP" mode or "SAFEOP"?in the terminal ,while I used "ethercat sl" command ,it did show up connected to DM3E-556 but while
LCNC starts?
Time to create page: 0.145 seconds
