Servo HCFA Y7
2 years 2 months ago #308632 by wm56
Servo HCFA Y7 was created by wm56
 Hi .
I recently purchased HCFA HN-Y7FB040A-S servos. Linuxcnc installation with Ethercat went well, but I don't know what to do next. How to configure it all. I've been working on it for a long time and nothing comes to mind. I'm mainly interested in the .xml file, how to go about it.
I received a configuration file from the manufacturer, but what to do with it next?
I'm new to ethercat. If I don't have a problem configuring mesa or lpt cards, I don't know how to deal with ethercat.
I have a project to complete to build my own machine and I would like to use these servos in it.
Please help. I'll be happy to return the favor.
File Name: HCFA_Y7_Se...1.24.xml
File Size:269.93 KB
2 years 2 months ago #308697 by dabiaoge6699
Replied by dabiaoge6699 on topic Servo HCFA Y7
你需要安装cia402 并把CIA402中的HAL 文件和XML 文件拷贝到你的机床文件 然后根据伺服XML的描述来更改CIA402中的XML文件 然后更改HAL文件
2 years 2 months ago #308700 by dabiaoge6699
你需要去HCFA官网去下载对应你型号的伺服驱动器说明书 根据说明书改伺服驱动器的控制模式
2 years 2 months ago #308822 by wm56
Replied by wm56 on topic Servo HCFA Y7
Thank you for the tips. Would you be able to help me with a tip or best of all give examples of how to do it, create a working configuration. Is the file I have good for configuration?
2 years 2 months ago #308834 by dabiaoge6699
抱歉,我英语不会,只能中文和你交流,你需要先设置伺服驱动器的控制模式,手册里有设置的方法,我用的也是禾川的伺服,不知道你的是不是和我一样的设置方法,控制模式设置到7,ethercat控制模式. 然后使用ethercat slaves命令查询伺服是否连接到,然后使用sudo ethercat csteuct命令来查询PID和VID,就是图片里的Vendor ID和Produce codm,然后记录好这两个ID,在打开XML文件,把XML文件里的VID和PID替换成你的,我发给你几个文件,你可以看一下,可能对你有所帮助
File Name: axis_mm.ini
File Size:4.93 KB
File Name: ethercat-c...8-27.xml
File Size:4.86 KB
File Name: lathe2-nopid.hal
File Size:4.33 KB
2 years 2 months ago #308835 by dabiaoge6699
抱歉,我想发给你pid和vid图片的,但是他超出了1.6mb的文件限制,如果你需要的话可以留下邮箱,我使用邮箱发送给你
Time to create page: 0.197 seconds
