Hi everyone,
I am part of a research group here at Iowa State and we are using LinuxCNC to build a laser based directed energy deposition system. We have some Omron G5 R88D-KN01L-ECT drivers that a few other people have seemed to have gotten working on here and I was hoping you might be able to provide some input if this describes you.
Right now I'm just trying to get position exchange information in the HAL viewer for a single axis.
Thanks to the
Ethercat installation from repositories - how to step by step
, and
EtherCAT: How to use the dedicated OmrG5 lcec driver?
I think I have the XML setup correctly, as the driver is happy and displays "--" (preop, waiting, no error) until I launch LinuxCNC, which about 1-2s after the main UI loads the driver drops into the '90' error. This occurs regardless of if I have the drive configured as a "generic" device or if I use the OmrG5 driver. I've also tried changing the servo thread cycle time through all of the supported cycle times listed in the documentation (0.5, 1, 2, & 4ms) and no change in behavior.
I've also tried Beckhoff's Ethercat Configurator to make sure that the cycle time was set appropriately
I've attached a snippet of the documentation for the communications synchronization error. Any help/thoughts would be incredibly appreciated as I've been banging my head against this wall for a few days now. The XML, INI and HAL files have also been attached.
Thanks!
