Help to configure external start button and external emergency button, EK1100
1 year 5 months ago #328004 by Leuo_
Hello,
Iam using EK1100 coupler and EL1008 for inputs and EL2008 to outputs, i try make in .hal file the configuration to use external buttons for Start and Emergency, how i can make in .hal file to link the rights io's ins .hal file.
Thanks for the help.
1 year 5 months ago #328122 by CORBETT
@Leuo_
Follow either of these two links and in the first post go down to PART 6 - LET’S SEE ETHERCAT WORK IN THE REAL WORLD .  There are detailed instructions on how to do the external Stop button and you should see how to do a start button also.
Ethercat build from source - full instructions - LinuxCNC
Ethercat build from source instructions - Updated for 2024 - LinuxCNC
Hope it helps,
Robert
The following user(s) said Thank You: onceloved
1 year 5 months ago #328293 by Leuo_
Hello Corbett
Thank you very much!
I'll try it here
Time to create page: 0.202 seconds
