The manual for your drive (pages 27–28) shows that Digital Output 5 (pins 19–20) and Digital Output 6 (pins 21–22) are digital output pairs rated to switch loads up to 200 mA. Output 6 can be used to send a stop signal to your system, indicating that the drive has entered stop mode.If your goal is to feed an external E‑stop signal into the drive, you must wire that signal to digital input IN1 (Servo Enable) as shown in the wiring diagram on page 26.The reference to “differential input” in the documentation is simply a translation error and can be disregarded.
