How to jog when beyond soft limits
1 year 4 months ago #330229 by kubes
I have soft limits on my axis and absolute encoders. If I power off the machine when I am on the limit (max or min), the machine may move by a 10th (0.0001) or so, once the servos release on power off.  This will cause the machine to "move beyond" the soft limit, even if just 0.0001.  Once this occurs, I can't jog the axis at all.  I have to edit the limits in the ini, jog and reset the limits back.
I would expect you can jog toward the soft limit and beyond to get back into the limits.  How can I jog into the limits is I am just slightly over (but over)
1 year 4 months ago #330230 by tommylight
1 year 4 months ago #330232 by kubes
Probe Basic
Not sure what you mean by tandem axis/joint. It's a mill so three axis, defined with axis_ and joint_
To that point, the issue is both before home and after, so joint and axis.
1 year 4 months ago #330425 by kubes
I have soft limits on my axis and absolute encoders (always homed, and to limit or homing switches). If I power off the machine when I am on the limit (max or min), the machine may move by a  few10th (0.0001) or so, once the servos release on power off.  This will cause the machine to "move beyond" the soft limit, even if just 0.0001.  Once this occurs, I can't jog the axis at all.  I have to edit the limits in the ini, jog and reset the limits back.
I see in WCS, there are limits override, but maybe it only works with hard limits and limit switches?
1 year 4 months ago #330429 by tommylight
Don't, just do not double post, it will not help you and will make a mess for us trying to keep stuff clean here.
Much better to post more info about your machine and how the homing is set up, and uploading config files usually helps a lot.
1 year 4 months ago #330431 by kubes
The last comment made is seem like a UI issue and being a week without anyone responsding. I tried to move but I could not figure how to move it.
Time to create page: 0.448 seconds
