Hello everyone,
I just got a Stepperonline A6 750W ethercat servo motor and drive and am making pretty good progress with it, at the moment just 1 axis to play around.
It is going into OP mode, I can jog it in gmoccapy, but I am having trouble with homing.
I have attached an inductive sensor to the drive, and can use this to home it in the software of stepperonline, but I dont get it to home in gmoccapy.
I am trying to use marcoreps el8_homecomp.comp, but I dont get the drive into opmode 6 for homing.
If I set the cia402.0.home in halshow the drive goes into opmode 6, and is homing, but I can not get it into opmode 6 it with the button in gmoccapy, and I also dont get feedback as soon as it has finished homing.
Not sure if this part in my HAL file is doing anything when I press the button:
# homing
#net x-home-request joint.0.request-custom-homing => cia402.0.home
#net x-homing joint.0.is-custom-homing <= cia402.0.stat-homing
#net x-homed joint.0.custom-homing-finished <= cia402.0.stat-homed
Would be happy if someone can help me.
Thanks!
