Leadshine 2CS3E-D507 / Cia402 almost working - help please!
1 year 1 month ago #335645 by jrc
Many thanks! I am away today but will give it a try tomorrow and report back. I might also try making an even simpler test machine configuration with only xy coordinates, trivkins, drive by just one 2CS3E-D507 dual-stepper drive, This should hopefully be easier to debug due to having less confounding variables
1 year 4 weeks ago #335700 by jrc
I had a bit of time today to try things out.
I did as you suggested and commented out the line which includes the basic_sim.tcl line
This produced a different error - it was unable to add all the servo-thread entries
" HAL :  ERROR: thread 'servo-thread' not found  "
 Looking into basic_sim.tcl I can find no instances of servo-thread.
However, basic_sim.tcl includes another file in line 33 called sim_lib.tcl
sim_lib.tcl has servo-thread appear in a lot of places
So it seems like some version of it is needed if we go the route of recycling one of the sim configs as a starting point
Any ideas on how to solve this one?
As a different possible solution, I created a different XYZ machine using two units of 2CS3E-D507, where the first one handles X and Y and the second handles Z. That way we start out totally away from the possible comlplications from the sim universe and directly go to a machine that only has two real, Ethercat devices,
This seems to load OK, but LinuxCNC starts up with the e-stop engaged and won't let me toggle it off.
The configs I created for this are:
ethercat-conf-xml:
<masters>   <master idx="0" appTimePeriod="1000000" refClockSyncCycles="-1">     <slave idx="0" type="2CS3E-D507">         <!-- <dcConf assignActivate="700" sync0Cycle="*1" sync0Shift="0" sync1Cycle="*1" sync1Shift="0"/> -->         <dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>       </slave>     <slave idx="1" type="2CS3E-D507">         <!-- <dcConf assignActivate="700" sync0Cycle="*1" sync0Shift="0" sync1Cycle="*1" sync1Shift="0"/> -->         <dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>       </slave>   </master> </masters>
machine_xyz.ini:
[EMC] MACHINE = machine_xyz VERSION = 1.1 DEBUG=0x00000242 [DISPLAY] DISPLAY = axis MAX_LINEAR_VELOCITY = 1 [TASK] TASK = milltask CYCLE_TIME = 0.001 [RS274NGC] # NoneType object has no attribute 'rfind' PARAMETER_FILE = machine_xyz.var [EMCIO] EMCIO = io CYCLE_TIME = 0.100 [EMCMOT] EMCMOT = motmod SERVO_PERIOD = 1000000 [HAL] # new addition to test Leadshine 2CS3E-D507 HALFILE = 2CS3E_D507xyz.hal [TRAJ] COORDINATES = XYZ LINEAR_UNITS = mm ANGULAR_UNITS = degree DEFAULT_LINEAR_VELOCITY = 2.50 MAX_LINEAR_VELOCITY = 25.00 [KINS] JOINTS = 3 KINEMATICS = trivkins coordinates=XYZ #*** AXIS_X ******************************* [AXIS_X] MAX_VELOCITY = 50.0 MAX_ACCELERATION = 750.0 MIN_LIMIT = -300.0 MAX_LIMIT = 300.0 [JOINT_0] TYPE = LINEAR HOME = 0.0 MIN_LIMIT = -300.0 MAX_LIMIT = 300.0 MAX_VELOCITY = 25.0 MAX_ACCELERATION = 750.0 #*** AXIS_Y ******************************* [AXIS_Y] MAX_VELOCITY = 25.0 MAX_ACCELERATION = 750.0 MIN_LIMIT = -300.0 MAX_LIMIT = 300.0 [JOINT_1] TYPE = LINEAR HOME = 0.0 MIN_LIMIT = -300.0 MAX_LIMIT = 300.0 MAX_VELOCITY = 25.0 MAX_ACCELERATION = 750.0 #*** AXIS_Z ******************************* [AXIS_Z] MAX_VELOCITY = 25.0 MAX_ACCELERATION = 750.0 MIN_LIMIT = -300.0 MAX_LIMIT = 300.0 [JOINT_2] TYPE = LINEAR HOME = 0.0 MIN_LIMIT = -300.0 MAX_LIMIT = 300.0 MAX_VELOCITY = 25.0 MAX_ACCELERATION = 750.0
2CS3E_D507.hal
loadrt [KINS]KINEMATICS loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=3 loadusr -W lcec_conf ethercat-conf.xml loadrt lcec loadrt cia402 count=3 addf lcec.read-all            servo-thread addf cia402.0.read-all        servo-thread addf cia402.1.read-all        servo-thread addf cia402.2.read-all        servo-thread addf motion-command-handler   servo-thread addf motion-controller        servo-thread addf cia402.0.write-all       servo-thread addf cia402.1.write-all       servo-thread addf cia402.2.write-all       servo-thread addf lcec.write-all           servo-thread #******************* #  X axis  lcec.0.0 (x) cia402.0 joint.0 Y axis lcec.0.0 cia402.1 joint.1 Z axis lcec.0.1 cia402.1 joint 2 #******************* setp cia402.0.enable 1 #setp cia402.0.opmode 1 setp cia402.0.csp-mode 1 setp cia402.0.pos-scale 4000 # ethercat to cia402 driver net x-statusword      lcec.0.0.srv-1-cia-statusword  => cia402.0.statusword net x-opmode-display  lcec.0.0.srv-1-opmode-display  => cia402.0.opmode-display net x-drv-act-pos     lcec.0.0.srv-1-actual-position => cia402.0.drv-actual-position net x-drv-act-vel     lcec.0.0.srv-1-actual-velocity => cia402.0.drv-actual-velocity # cia402 driver to ethercat net x-controlword         cia402.0.controlword         => lcec.0.0.srv-1-cia-controlword net x-modes-of-operation  cia402.0.opmode              => lcec.0.0.srv-1-opmode net x-drv-target-pos      cia402.0.drv-target-position => lcec.0.0.srv-1-target-position #from motion to cia net x-enable    <= joint.0.amp-enable-out => cia402.0.enable net x-amp-fault => joint.0.amp-fault-in   <= cia402.0.drv-fault net x-pos-cmd   <= joint.0.motor-pos-cmd  => cia402.0.pos-cmd net x-pos-fb    => joint.0.motor-pos-fb   <= cia402.0.pos-fb ## Y axis ## setp cia402.1.enable 1 #setp cia402.1.opmode 1 setp cia402.1.csp-mode 1 setp cia402.1.pos-scale 4000 # ethercat to cia402 driver net y-statusword      lcec.0.0.srv-2-cia-statusword  => cia402.1.statusword net y-opmode-display  lcec.0.0.srv-2-opmode-display  => cia402.1.opmode-display net y-drv-act-pos     lcec.0.0.srv-2-actual-position => cia402.1.drv-actual-position net y-drv-act-vel     lcec.0.0.srv-2-actual-velocity => cia402.1.drv-actual-velocity # cia402 driver to ethercat net y-controlword         cia402.1.controlword         => lcec.0.0.srv-2-cia-controlword net y-modes-of-operation  cia402.1.opmode              => lcec.0.0.srv-2-opmode net y-drv-target-pos      cia402.1.drv-target-position => lcec.0.0.srv-2-target-position #from motion to cia net y-enable    <= joint.1.amp-enable-out => cia402.1.enable net y-amp-fault => joint.1.amp-fault-in   <= cia402.1.drv-fault net y-pos-cmd   <= joint.1.motor-pos-cmd  => cia402.1.pos-cmd net y-pos-fb    => joint.1.motor-pos-fb   <= cia402.1.pos-fb # homing #net y-home-request joint.1.request-custom-homing => cia402.1.home #net y-homing joint.1.is-custom-homing <= cia402.1.stat-homing #net y-homed joint.1.custom-homing-finished <= cia402.1.stat-homed ## Z axis ## setp cia402.2.enable 1 #setp cia402.2.opmode 1 setp cia402.2.csp-mode 1 setp cia402.2.pos-scale 4000 # ethercat to cia402 driver net z-statusword      lcec.0.1.srv-1-cia-statusword  => cia402.2.statusword net z-opmode-display  lcec.0.1.srv-1-opmode-display  => cia402.2.opmode-display net z-drv-act-pos     lcec.0.1.srv-1-actual-position => cia402.2.drv-actual-position net z-drv-act-vel     lcec.0.1.srv-1-actual-velocity => cia402.2.drv-actual-velocity # cia402 driver to ethercat net z-controlword         cia402.2.controlword         => lcec.0.1.srv-1-cia-controlword net z-modes-of-operation  cia402.2.opmode              => lcec.0.1.srv-1-opmode net z-drv-target-pos      cia402.2.drv-target-position => lcec.0.1.srv-1-target-position #from motion to cia net z-enable    <= joint.2.amp-enable-out => cia402.2.enable net z-amp-fault => joint.2.amp-fault-in   <= cia402.2.drv-fault net z-pos-cmd   <= joint.2.motor-pos-cmd  => cia402.2.pos-cmd net z-pos-fb    => joint.2.motor-pos-fb   <= cia402.2.pos-fb # homing #net z-home-request joint.2.request-custom-homing => cia402.2.home #net z-homing joint.2.is-custom-homing <= cia402.2.stat-homing #net z-homed joint.2.custom-homing-finished <= cia402.2.stat-homed
Any ideas on how to get this one to start? I tried to make it as basic as possible to avoid anything else distracting things.
To reiterate, it loads correctly and LinuxCNC starts without an error screen popping up, but the e-stop on the top left of the axis interface screen is toggled on when it starts and can't be toggled off.
ethercat slaves shows both 2CS3E-D507 slaves in OP state
1 year 4 weeks ago #335708 by Hakan
From that example/template I linked to before, you need
net emc-enable => iocontrol.0.emc-enable-in sets emc-enable 1
in the hal file.
That should allow it to start I think.
That example/template is a working example. You have a bit different naming due to two motors per drive, but other than that it should work.
1 year 4 weeks ago - 1 year 4 weeks ago #335767 by jrc
 Many thanks!That got it to work beautifully and I can now easily jog the motors etc., the machine e-stop and machine start buttons on the screen work etc.
Last edit: 1 year 4 weeks ago by jrc. Reason: Totally mangled formatting (my fault)
1 year 4 weeks ago #335768 by jrc
However, this was done with each motor associated with an axis (X, Y, Z), and what I am ultimately aiming for is to get the steppers on the 2CS3E-D507 to drive joints in a carousel instead of axis in a coordinate system, so they need to be "joints without an associated axis letter" and still work.
How does one achieve this?
The existing working config has a dual-axis 2CS3E-D507 driving X and Y, and a second 2CS3E-D507 driving Z, with one spare motor left.
I tried setting that one up as a new "joint without associated axis" [JOINT_3] in the config, and this caused it to stop working again.The updated hal file using the spare stepper as an extra joint is:
loadrt [KINS]KINEMATICS loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=4 loadusr -W lcec_conf ethercat-conf.xml loadrt lcec loadrt cia402 count=4 addf lcec.read-all            servo-thread addf cia402.0.read-all        servo-thread addf cia402.1.read-all        servo-thread addf cia402.2.read-all        servo-thread addf cia402.3.read-all        servo-thread addf motion-command-handler   servo-thread addf motion-controller        servo-thread addf cia402.0.write-all       servo-thread addf cia402.1.write-all       servo-thread addf cia402.2.write-all       servo-thread addf cia402.3.write-all       servo-thread addf lcec.write-all           servo-thread #******************* #  X axis  lcec.0.0 arm (x) cia402.0 joint.0 (y) lcec.0.0 cia402.1 joint.1 z lcec.0.1 cia402.1 joint 2 #******************* setp cia402.0.enable 1 setp cia402.0.csp-mode 1 setp cia402.0.pos-scale 4000 # ethercat to cia402 driver net x-statusword      lcec.0.0.srv-1-cia-statusword  => cia402.0.statusword net x-opmode-display  lcec.0.0.srv-1-opmode-display  => cia402.0.opmode-display net x-drv-act-pos     lcec.0.0.srv-1-actual-position => cia402.0.drv-actual-position net x-drv-act-vel     lcec.0.0.srv-1-actual-velocity => cia402.0.drv-actual-velocity # cia402 driver to ethercat net x-controlword         cia402.0.controlword         => lcec.0.0.srv-1-cia-controlword net x-modes-of-operation  cia402.0.opmode              => lcec.0.0.srv-1-opmode net x-drv-target-pos      cia402.0.drv-target-position => lcec.0.0.srv-1-target-position #from motion to cia net x-enable    <= joint.0.amp-enable-out => cia402.0.enable net x-amp-fault => joint.0.amp-fault-in   <= cia402.0.drv-fault net x-pos-cmd   <= joint.0.motor-pos-cmd  => cia402.0.pos-cmd net x-pos-fb    => joint.0.motor-pos-fb   <= cia402.0.pos-fb ## Y axis ## setp cia402.1.enable 1 setp cia402.1.csp-mode 1 setp cia402.1.pos-scale 4000 # ethercat to cia402 driver net y-statusword      lcec.0.0.srv-2-cia-statusword  => cia402.1.statusword net y-opmode-display  lcec.0.0.srv-2-opmode-display  => cia402.1.opmode-display net y-drv-act-pos     lcec.0.0.srv-2-actual-position => cia402.1.drv-actual-position net y-drv-act-vel     lcec.0.0.srv-2-actual-velocity => cia402.1.drv-actual-velocity # cia402 driver to ethercat net y-controlword         cia402.1.controlword         => lcec.0.0.srv-2-cia-controlword net y-modes-of-operation  cia402.1.opmode              => lcec.0.0.srv-2-opmode net y-drv-target-pos      cia402.1.drv-target-position => lcec.0.0.srv-2-target-position #from motion to cia net y-enable    <= joint.1.amp-enable-out => cia402.1.enable net y-amp-fault => joint.1.amp-fault-in   <= cia402.1.drv-fault net y-pos-cmd   <= joint.1.motor-pos-cmd  => cia402.1.pos-cmd net y-pos-fb    => joint.1.motor-pos-fb   <= cia402.1.pos-fb ## Z axis ## setp cia402.2.enable 1 setp cia402.2.csp-mode 1 setp cia402.2.pos-scale 4000 # ethercat to cia402 driver net z-statusword      lcec.0.1.srv-1-cia-statusword  => cia402.2.statusword net z-opmode-display  lcec.0.1.srv-1-opmode-display  => cia402.2.opmode-display net z-drv-act-pos     lcec.0.1.srv-1-actual-position => cia402.2.drv-actual-position net z-drv-act-vel     lcec.0.1.srv-1-actual-velocity => cia402.2.drv-actual-velocity # cia402 driver to ethercat net z-controlword         cia402.2.controlword         => lcec.0.1.srv-1-cia-controlword net z-modes-of-operation  cia402.2.opmode              => lcec.0.1.srv-1-opmode net z-drv-target-pos      cia402.2.drv-target-position => lcec.0.1.srv-1-target-position #from motion to cia net z-enable    <= joint.2.amp-enable-out => cia402.2.enable net z-amp-fault => joint.2.amp-fault-in   <= cia402.2.drv-fault net z-pos-cmd   <= joint.2.motor-pos-cmd  => cia402.2.pos-cmd net z-pos-fb    => joint.2.motor-pos-fb   <= cia402.2.pos-fb ## extra joint with no associated axis (for later use in carousel)## setp cia402.3.enable 1 setp cia402.3.csp-mode 1 setp cia402.3.pos-scale 4000 # ethercat to cia402 driver net extra-statusword      lcec.0.1.srv-2-cia-statusword  => cia402.3.statusword net extra-opmode-display  lcec.0.1.srv-2-opmode-display  => cia402.3.opmode-display net extra-drv-act-pos     lcec.0.1.srv-2-actual-position => cia402.3.drv-actual-position net extra-drv-act-vel     lcec.0.1.srv-2-actual-velocity => cia402.3.drv-actual-velocity # cia402 driver to ethercat net extra-controlword         cia402.3.controlword         => lcec.0.1.srv-2-cia-controlword net extra-modes-of-operation  cia402.3.opmode              => lcec.0.1.srv-2-opmode net extra-drv-target-pos      cia402.3.drv-target-position => lcec.0.1.srv-2-target-position #from motion to cia net extra-enable    <= joint.3.amp-enable-out => cia402.3.enable net extra-amp-fault => joint.3.amp-fault-in   <= cia402.3.drv-fault net extra-pos-cmd   <= joint.3.motor-pos-cmd  => cia402.3.pos-cmd net extra-pos-fb    => joint.3.motor-pos-fb   <= cia402.3.pos-fb
I basically added an extra copy of the z axis cia402 bits and replaced "z" with "extra" and cia402.2 with cia402.3
The ini file with the extra "joint with no axis letter name" is
[EMC] MACHINE = machine_xyz VERSION = 1.1 DEBUG=0x00000242 [DISPLAY] DISPLAY = axis MAX_LINEAR_VELOCITY = 1 [TASK] TASK = milltask CYCLE_TIME = 0.001 [RS274NGC] PARAMETER_FILE = machine_xy.var [EMCIO] EMCIO = io CYCLE_TIME = 0.100 [EMCMOT] EMCMOT = motmod SERVO_PERIOD = 1000000 [HAL] HALFILE = 2CS3E_D507xyz.hal # NOTE: Must have consistent values for # [TRAJ]COORDINATES = LETTERS # [KINS]JOINTS      = Number_of_JOINTs # [KINS]KINEMAITICS = trivkins coordinates=LETTERS [TRAJ] COORDINATES = XYZ LINEAR_UNITS = mm ANGULAR_UNITS = degree DEFAULT_LINEAR_VELOCITY = 2.50 MAX_LINEAR_VELOCITY = 25.00 [KINS] JOINTS = 4 KINEMATICS = trivkins coordinates=XYZ #*** AXIS_X ******************************* [AXIS_X] MAX_VELOCITY = 50.0 MAX_ACCELERATION = 750.0 MIN_LIMIT = -300.0 MAX_LIMIT = 300.0 [JOINT_0] TYPE = LINEAR HOME = 0.0 MIN_LIMIT = -300.0 MAX_LIMIT = 300.0 MAX_VELOCITY = 25.0 MAX_ACCELERATION = 750.0 #*** AXIS_Y ******************************* [AXIS_Y] MAX_VELOCITY = 25.0 MAX_ACCELERATION = 750.0 MIN_LIMIT = -300.0 MAX_LIMIT = 300.0 [JOINT_1] TYPE = LINEAR HOME = 0.0 MIN_LIMIT = -300.0 MAX_LIMIT = 300.0 MAX_VELOCITY = 25.0 MAX_ACCELERATION = 750.0 #*** AXIS_Z ******************************* [AXIS_Z] MAX_VELOCITY = 25.0 MAX_ACCELERATION = 750.0 MIN_LIMIT = -300.0 MAX_LIMIT = 300.0 [JOINT_2] TYPE = LINEAR HOME = 0.0 MIN_LIMIT = -300.0 MAX_LIMIT = 300.0 MAX_VELOCITY = 25.0 MAX_ACCELERATION = 750.0 [JOINT_3] TYPE = LINEAR HOME = 0.0 MIN_LIMIT = -300.0 MAX_LIMIT = 300.0 MAX_VELOCITY = 25.0 MAX_ACCELERATION = 750.0
The reason for wanting a pure joint instead of a joint linked to an axis is that that is supposed to be the preferable way to drive the carousel component (as opposed to repurposing unused axis letters, eg. out of XZYABC recycling the B and C to drive the carousel if you only have a 4 axis machine.
However, when I add this extra joint the previously working 3 axis (XYZ) system fails to start. The error might be hinting at a mismatch between the number of joints and axes:
  File "/usr/bin/axis", line 3655, in <module>
    ja_id = aletter_for_jnum(jnum)
  File "/usr/bin/axis", line 3642, in aletter_for_jnum
    return trivkinscoords.upper()[jnum]
IndexError: string index out of range
Any ideas on what could be going on?
1 year 4 weeks ago #335769 by jrc
The complete error file is attached here
Time to create page: 0.107 seconds
