Festo CMMT-ST
1 year 6 days ago #337229 by andypugh
Replied by andypugh on topic Festo CMMT-ST
Your kinematics setup seems to be wrong:
[KINS] JOINTS = 3 KINEMATICS = trivkins coordinates=XYZ
Should be 5 joints and probably XYYZZ
1 year 6 days ago #337232 by lorenzing
Replied by lorenzing on topic Festo CMMT-ST
Hi andypugh, jc2ktr shared his working setup, but here is mine:
[KINS] JOINTS = 5 KINEMATICS = trivkins coordinates=XYYZZ kinstype=BOTH
1 year 5 days ago #337304 by jc2ktr
Replied by jc2ktr on topic Festo CMMT-ST
Thank you all very much for the support. The drives use the CiA402 protocol, with the jc2ktr setup I was able to see the drives and I can perform jogging, but I don't understand why I see Z1 on joint 0, which should be X. And when I try to jog joint 1, joint 0 always moves. I definitely made a lot of confusion in the HAL file.
Maybe your Hardware (ethercat ports, or motorcables) are wired wrong, your halfile looks okay to me?
I´ve had at work that if you swap in and out of the Ethercat ports you get weird behavior on the EC-Bus.
1 year 5 days ago #337307 by tommylight
Replied by tommylight on topic Festo CMMT-ST
cia402.4.xxxxx
That is in your hal file for the X axis, it should be
cia402.0.xxxxx
if you want X to be the first joint/axis.
Same for other joints and axis, and there are multiple instances for each joint to be changed.
11 months 4 weeks ago #337701 by lorenzing
Thank you so much, now looks good.
Can someone help me with "setp cia402.X.pos-scale 3600" value?
I've this type of motor with the same encoder: EMMB-ST-87-M-SM (X), EMMB-ST-87-M-SMB (Z1,Z2,Y1,Y2).
Z1, Z2 5mm/rev; X, Y1, Y2 180mm/rev.
11 months 1 week ago #338799 by lorenzing
Many problems have been solved by assigning numbers instead of the axis letter (e.g. X) in the .hal file probably generated errors as there were two motors for one axis.
# --- load components --- loadrt [KINS]KINEMATICS loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS  # load EtherCAT xml then drivers loadusr -W lcec_conf ethercat-conf.xml loadrt lcec loadrt cia402 count=5 # --- add functions to servo-thread --- addf lcec.read-all            servo-thread # read from cia402 drivers (one per joint) addf cia402.0.read-all        servo-thread addf cia402.1.read-all        servo-thread addf cia402.2.read-all        servo-thread addf cia402.3.read-all        servo-thread addf cia402.4.read-all        servo-thread # motion stack addf motion-command-handler   servo-thread addf motion-controller        servo-thread # writes: cia402 then lcec addf cia402.0.write-all       servo-thread addf cia402.1.write-all       servo-thread addf cia402.2.write-all       servo-thread addf cia402.3.write-all       servo-thread addf cia402.4.write-all       servo-thread addf lcec.write-all           servo-thread # estop net estop-out  iocontrol.0.user-enable-out => iocontrol.0.emc-enable-in # ========================= # JOINT 0  (X)  -> cia402.0 -> lcec.0.0 # ========================= #config setp cia402.0.csp-mode 1 setp cia402.0.pos-scale -3600 #from servo(ethercat) to cia402 net 0-statusword      lcec.0.0.srv-cia-statusword => cia402.0.statusword net 0-opmode-display  lcec.0.0.srv-opmode-display => cia402.0.opmode-display net 0-drv-act-pos     lcec.0.0.srv-actual-position => cia402.0.drv-actual-position net 0-drv-act-velo    lcec.0.0.srv-actual-velocity => cia402.0.drv-actual-velocity #from cia402 to servo(ethercat)  net 0-controlword         cia402.0.controlword => lcec.0.0.srv-cia-controlword net 0-modes-of-operation  cia402.0.opmode => lcec.0.0.srv-opmode net 0-drv-target-pos      cia402.0.drv-target-position => lcec.0.0.srv-target-position #from motion to cia net 0-enable    <= joint.0.amp-enable-out => cia402.0.enable net 0-amp-fault => joint.0.amp-fault-in   <= cia402.0.drv-fault net 0-pos-cmd   <= joint.0.motor-pos-cmd  => cia402.0.pos-cmd net 0-pos-fb    => joint.0.motor-pos-fb   <= cia402.0.pos-fb # ========================= # JOINT 1  (Y1) -> cia402.1 -> lcec.0.2 # ========================= #config setp cia402.1.csp-mode 1 setp cia402.1.pos-scale -3600 #from servo(ethercat) to cia402 net 1-statusword      lcec.0.2.srv-cia-statusword => cia402.1.statusword net 1-opmode-display  lcec.0.2.srv-opmode-display => cia402.1.opmode-display net 1-drv-act-pos     lcec.0.2.srv-actual-position => cia402.1.drv-actual-position net 1-drv-act-velo    lcec.0.2.srv-actual-velocity => cia402.1.drv-actual-velocity #from cia402 to servo(ethercat)  net 1-controlword         cia402.1.controlword => lcec.0.2.srv-cia-controlword net 1-modes-of-operation  cia402.1.opmode => lcec.0.2.srv-opmode net 1-drv-target-pos      cia402.1.drv-target-position => lcec.0.2.srv-target-position #from motion to cia net 1-enable    <= joint.1.amp-enable-out => cia402.1.enable net 1-amp-fault => joint.1.amp-fault-in   <= cia402.1.drv-fault net 1-pos-cmd   <= joint.1.motor-pos-cmd  => cia402.1.pos-cmd net 1-pos-fb    => joint.1.motor-pos-fb   <= cia402.1.pos-fb # ========================= # JOINT 2  (Y2) -> cia402.2 -> lcec.0.1 # ========================= #config setp cia402.2.csp-mode 1 setp cia402.2.pos-scale 3600 #from servo(ethercat) to cia402 net 2-statusword      lcec.0.1.srv-cia-statusword => cia402.2.statusword net 2-opmode-display  lcec.0.1.srv-opmode-display => cia402.2.opmode-display net 2-drv-act-pos     lcec.0.1.srv-actual-position => cia402.2.drv-actual-position net 2-drv-act-velo    lcec.0.1.srv-actual-velocity => cia402.2.drv-actual-velocity #from cia402 to servo(ethercat)  net 2-controlword         cia402.2.controlword => lcec.0.1.srv-cia-controlword net 2-modes-of-operation  cia402.2.opmode => lcec.0.1.srv-opmode net 2-drv-target-pos      cia402.2.drv-target-position => lcec.0.1.srv-target-position #from motion to cia net 2-enable    <= joint.2.amp-enable-out => cia402.2.enable net 2-amp-fault => joint.2.amp-fault-in   <= cia402.2.drv-fault net 2-pos-cmd   <= joint.2.motor-pos-cmd  => cia402.2.pos-cmd net 2-pos-fb    => joint.2.motor-pos-fb   <= cia402.2.pos-fb # ========================= # JOINT 3  (Z1) -> cia402.3 -> lcec.0.4 # ========================= #config setp cia402.3.csp-mode 1 setp cia402.3.pos-scale 3600 #from servo(ethercat) to cia402 net 3-statusword      lcec.0.4.srv-cia-statusword => cia402.3.statusword net 3-opmode-display  lcec.0.4.srv-opmode-display => cia402.3.opmode-display net 3-drv-act-pos     lcec.0.4.srv-actual-position => cia402.3.drv-actual-position net 3-drv-act-velo    lcec.0.4.srv-actual-velocity => cia402.3.drv-actual-velocity #from cia402 to servo(ethercat)  net 3-controlword         cia402.3.controlword => lcec.0.4.srv-cia-controlword net 3-modes-of-operation  cia402.3.opmode => lcec.0.4.srv-opmode net 3-drv-target-pos      cia402.3.drv-target-position => lcec.0.4.srv-target-position #from motion to cia net 3-enable    <= joint.3.amp-enable-out => cia402.3.enable net 3-amp-fault => joint.3.amp-fault-in   <= cia402.3.drv-fault net 3-pos-cmd   <= joint.3.motor-pos-cmd  => cia402.3.pos-cmd net 3-pos-fb    => joint.3.motor-pos-fb   <= cia402.3.pos-fb # ========================= # JOINT 4  (Z2) -> cia402.4 -> lcec.0.3 # ========================= #config setp cia402.4.csp-mode 1 setp cia402.4.pos-scale 3600 #from servo(ethercat) to cia402 net 4-statusword      lcec.0.3.srv-cia-statusword => cia402.4.statusword net 4-opmode-display  lcec.0.3.srv-opmode-display => cia402.4.opmode-display net 4-drv-act-pos     lcec.0.3.srv-actual-position => cia402.4.drv-actual-position net 4-drv-act-velo    lcec.0.3.srv-actual-velocity => cia402.4.drv-actual-velocity #from cia402 to servo(ethercat)  net 4-controlword         cia402.4.controlword => lcec.0.3.srv-cia-controlword net 4-modes-of-operation  cia402.4.opmode => lcec.0.3.srv-opmode net 4-drv-target-pos      cia402.4.drv-target-position => lcec.0.3.srv-target-position #from motion to cia net 4-enable    <= joint.4.amp-enable-out => cia402.4.enable net 4-amp-fault => joint.4.amp-fault-in   <= cia402.4.drv-fault net 4-pos-cmd   <= joint.4.motor-pos-cmd  => cia402.4.pos-cmd net 4-pos-fb    => joint.4.motor-pos-fb   <= cia402.4.pos-fb # End of HAL
Time to create page: 0.198 seconds
