Following error due 2³¹ 2 147 483 648 jump to -2 147 483 648
10 months 1 week ago - 10 months 1 week ago #340497 by ts
Hi
I doing retrofit on machine, used etheecat delta.
i used in hal file scale parameter pos-scale to adjust lenght of movenent
today i catch an error, when linuxcnc receive value during moving equals +2^31 and became -2^31, system catch that prevous value pos of axis calculated in mm was 380mm, and after count +2^31 overflow became -67mm. So there an error.
I have no ideas, and stucked) How to solve this trouble?
thanks in advance!
Last edit: 10 months 1 week ago by ts.
10 months 1 week ago #340503 by Hakan
Never seen a several km long axis so I am out of clues, sorry.
10 months 1 week ago #340504 by endian
take a look at default resolution SDO .. it has to be something like 20 or 16 ... it is user resolution per revolution ... maybe it has some weird setup from factory ... you have maybe swapped bytes or something or wrong data type ....
you dont share anything ... maybe share more details for focused reply
10 months 1 week ago #340514 by ts
Thanks for your replies.
in my case delta etheecat asda a3e give me resolution om the motor at output on ethercat. In asda soft avaible option mul/div parameters for recalculation encodee output, but every reboot servodrive thats parameters became to 1. So i calculated (all mechanical reduction and motors encoder resolution) scale-pos, it about 9 500 000 to receive correct move command execution.
Of cpurse, maybe right way is to put parameters asda delta div/mul to scaledown , but may be there are some other way?
10 months 1 week ago #340521 by endian
you have to adjust the resolution over SDOs during start up and then to reduce it over float factor in the SMs ... if you are scaling 1 / something big it will just create you crazy numbers then ...
share config at first place ... then we can help you well
7 months 1 week ago - 7 months 1 week ago #344706 by ts
Thanks for your replyes. Yes, you right, i have to add this strings to xml config and every loading linuxcnc write electronic gear values to delta servo drive :
<slave idx="3" type="generic" vid="0x000001dd" pid="0x00006010" configPdos="true"> <!-- Axis Z -->
<sdoConfig idx="6093" subIdx="1">
<sdoDataRaw data="00 00 00 01"/> <!-- 01000000h= 16777216 P1.44-->
</sdoConfig>
<sdoConfig idx="6093" subIdx="2">
<sdoDataRaw data="d6 06"/>
</sdoConfig>
<dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>
Last edit: 7 months 1 week ago by ts.
Time to create page: 0.064 seconds
