Separating CiA402 Logic from EtherCAT (lcec): Modular Adapter + Drive Stub Valid
8 months 5 days ago - 8 months 5 days ago #343595 by Marcos DC
I’m currently restructuring my CiA402 integration to make it more modular and deterministic before going back to real EtherCAT hardware.
Instead of debugging everything at once (LinuxCNC motion + EtherCAT + CiA402 + drive behavior), I decided to isolate the CiA402 logic layer and validate it independently inside AXIS SIM.
Overall Structure (3 Layers)
I’m organizing the system into three logical layers:
1) Motion Layer (LinuxCNC)
Standard LinuxCNC motion/joint layer. No changes here.
2) CiA402 Adapter Layer (custom HAL component)
This is a dedicated HAL component responsible for:
  • Mode request (6060), e.g. Homing = 6, CSP = 8
  • Waiting for 6061 (opmode_display) confirmation before proceeding
  • Generating controlword transitions (6040), including homing start (bit 4)
  • Mask/value-based evaluation of statusword (6041) for homing done
  • Optional mask/value error detection
  • Slaving pos_cmd to pos_fb during internal drive homing
This layer does not know about EtherCAT transport.
It only works with abstract CiA402 objects (6040, 6041, 6060, 6061, 6064).The idea is that this logic should work identically whether the transport is:
  • lcec (EtherCAT)
  • some other fieldbus
  • or a simulated drive
3) Drive Stub (Simulated CiA402 Drive in HAL)
Since I don’t have EtherCAT hardware connected right now, I implemented a simple CiA402 drive stub as a HAL component.
It simulates:
  • Opmode request → opmode_display with delay
  • Rising edge detection of controlword bit 4
  • Homing runtime (configurable cycles)
  • Statusword “homing done” pattern (e.g. 0x1400 by default)
  • Actual position feedback
This allows me to validate:
  • Proper gating on 6061
  • Correct controlword sequencing
  • Deterministic servo-thread behavior
  • Statusword mask handling
  • HAL wiring correctness
All running inside AXIS SIM.
Relation to Existing Work (rodw, dbraun, EL8)I’ve reviewed:
  • dbraun’s hal-cia402 implementation
  • rodw’s cia402 component used with lcec
  • The Leadshine EL8 integration example
All of them are valid and functional in their intended context.However, my goal here is slightly different:I want a clearly separated CiA402 logic layer that:
  • Can be tested without EtherCAT
  • Is not tightly coupled to lcec internals
  • Can support both internal drive homing and CSP cleanly
  • Can later be extended for tandem gantry supervision (Y/Y0 squaring)
This isolation makes debugging much more controlled and avoids mixing transport issues with state-machine issues.
Why Mask-Based Statusword Evaluation?
Instead of hard-coding something like “bit 12 = homing done”, I’m using:(statusword & mask) == valueExample:0x1400 (bits 10 + 12)The reason is simple:CiA402 allows vendor-specific interpretation and combination of bits.
Different drives report homing completion differently (sometimes bit 12 only, sometimes 10+12, sometimes additional bits).A mask/value approach allows:
  • Drive-specific configuration
  • Future-proofing
  • Cleaner abstraction
If mask = 0, the adapter falls back to default CiA402-style bit interpretation.
Long-Term GoalThe final architecture should support:
  • CSP as primary motion mode
  • Internal drive homing
  • Tandem gantry (Y/Y0) with squaring
  • Optional gantry delta supervision during homing
  • Clear separation between CiA402 state logic and EtherCAT transport
So conceptually:Motion → CiA402 Adapter → Transport (lcec) → DriveAnd currently:Motion → CiA402 Adapter → HAL Drive StubOnce validated, I’ll replace the stub with real lcec + cia402.If anyone has feedback regarding:
  • Best practices for controlword sequencing in CSP
  • Clean homing mode transitions
  • Gantry homing supervision patterns
  • Mask-based statusword handling
I’d appreciate technical input.
Last edit: 8 months 5 days ago by Marcos DC.
The following user(s) said Thank You: andrax, onceloved, NWE
8 months 5 days ago #343623 by NWE
Thanks!
I have not studied internals of CiA402 very deeply. However, I have some EtherCAT hardware here, I'd be willing to test your component on my drives once you get to that stage of the project.
8 months 4 days ago #343631 by rodw
The bare bones CIA402 state machine looks like this:
// uncomment pins if enabled /* --- CiA 402 Controlword Commands --- */ #define CMD_SHUTDOWN 0x0006 // Transition to Ready to Switch On #define CMD_SWITCH_ON 0x0007 // Transition to Switched On #define CMD_DISABLE_VOLTAGE 0x0000 // Disable power stage #define CMD_QUICK_STOP 0x0002 // Emergency deceleration #define CMD_DISABLE_OPERATION 0x0007 // Disable motor drive #define CMD_ENABLE_OPERATION 0x000F // Enable motor drive (Power On) #define CMD_FAULT_RESET 0x0080 // Reset fault on rising edge /* --- CiA 402 Statusword States --- */ // Masked with 0x006F to extract the specific state bits #define STATE_NOT_READY 0x0000 #define STATE_SWITCH_ON_DISABLED 0x0040 #define STATE_READY_TO_SWITCH_ON 0x0021 #define STATE_SWITCHED_ON 0x0023 #define STATE_OPERATION_ENABLED 0x0027 #define STATE_QUICK_STOP_ACTIVE 0x0007 #define STATE_FAULT_REACTION_ACTIVE 0x000F #define STATE_FAULT 0x0008 uint16_t update_cia402_state(config_data_t *d) { // receives status.word ( d->status.raw) unsigned short currentState = d->status.raw & 0x006F; // removes all the bits we are not interested in switch (currentState) { case STATE_SWITCH_ON_DISABLED: d->control.raw = CMD_SHUTDOWN; break; case STATE_READY_TO_SWITCH_ON: d->control.raw = CMD_SWITCH_ON; break; case STATE_SWITCHED_ON: d->control.raw = CMD_ENABLE_OPERATION; break; case STATE_OPERATION_ENABLED: // Drive is active. Keep it enabled. d->control.raw = CMD_ENABLE_OPERATION; return 1; break; case STATE_FAULT: // Attempt to clear the fault d->control.raw = CMD_FAULT_RESET; break; case STATE_QUICK_STOP_ACTIVE: // Move back to disabled if quick stop was triggered d->control.raw = CMD_DISABLE_VOLTAGE; break; default: // For any unknown or intermediate state, default to a safe "Voltage Disable" d->control.raw = CMD_DISABLE_VOLTAGE; break; } return 0; }
You should add some timeouts for error handling
The following user(s) said Thank You: Marcos DC
8 months 4 days ago #343641 by Hakan
Have you looked at splitting the function one more step?
state-machine (bringing to op-enabled) : One component
op-mode module: Several components, csp, csv, homing, pv, pp, probing etc.
Looks appealing at first thought. Maybe switching between op-modes
and restoring position kills it though
8 months 4 days ago - 8 months 4 days ago #343647 by Marcos DC
Hi @rodw, @Hakan and everyone,
Thanks a lot for the input — this is really helpful.
@rodw, your barebone CiA402 state handler is exactly what I needed to properly structure the lower layer. The statusword & 0x006F decoding and the minimal enable sequence up to Operation Enabled fit perfectly as a clean PDS manager.
@Hakan, yes — I’m now looking at splitting things one step further, exactly as you suggest.
The structure I’m converging to is:
  1. PDS manager (CiA402 FSA layer)
    • Based on rodw’s barebone logic
    • Responsible only for bringing the drive from Switch On Disabled to Operation Enabled
    • No homing, no CSP logic inside
    • Exposes something like op_enabled
  2. Op-mode layer (separate modules)
    • CSP
    • CSV
    • Homing
    • PP / PV
    • Probing, etc.
      Each module only runs when op_enabled == true and after 6060/6061 handshake is confirmed.
  3. Application layer (drive-agnostic)
    • Homing bit4 pulse generation
    • done_mask / done_value evaluation
    • Error mask/value
    • All configurable via parameters (no hardcoded drive values)
The goal is to keep this fully drive-agnostic at the application level, using mask/value instead of fixed statusword comparisons.About the concern Hakan mentioned — “maybe switching op-modes and restoring position kills it” — I agree that’s the main trap.My current idea is:
  • On mode entry: temporarily slave pos_cmd := pos_fb (freeze target) until the drive confirms the new mode via 6061
  • Only then release control to avoid position jumps
  • Same approach on exit back to CSP
So mode switching becomes edge-triggered and gated, not a live swap.
To make sure I’m not inventing behavior, I’m using these two documents as formal references for the machine state and execution semantics:
  • CiA 402 – Part 2 (Operation Modes & PDS Finite State Automaton)
  • PLCopen Motion Control – Part 1 (FB Model & State Diagram)
Right now I’m validating all of this in a pure SIM environment (drive stub + HAL components), before integrating back into real EtherCAT hardware.
Also, just a small note: during the week I mostly work on this code at my job — evenings are usually family time (kids at home), so progress sometimes comes in structured blocks rather than daily updates. But I’m moving forward steadily.
If anyone has suggestions on best practices for mode handover (especially CSP ⇄ Homing) or additional references worth reading, I’d really appreciate it. ​​​​​​
[i][b][b][i][i][code][b][code][b][code][code][code][b][b] [/b][/b]
[/code][/code][/b][/code][/b][/code][/i][/i][/b][/b][/i][/code]
Last edit: 8 months 4 days ago by Marcos DC.
The following user(s) said Thank You: rodw, NWE
8 months 4 days ago #343651 by rodw
I don;t know if you noticed but that procedure returns 1 when the machine s turned on so until it does that, you just wait... Then you do all the homing and other things
The following user(s) said Thank You: NWE
