Python gcode.parse and gcode.calc_extents
- JT
- Thank you received: 593
25 May 2024 16:14 - 25 May 2024 16:16 #301417
by JT
Python gcode.parse and gcode.calc_extents was created by JT
I'm trying to figure out what gcode.parse and gcode.calc_extents does and how to use it. I've been grepping and searching for examples but I've not found out the syntax and what is returned.
Not much help there...
With axis running and a terminal open and running python3
grepping I find this example in src/emc/usr_intf/axis/scripts/axis.py:1589:
So what I'm trying to do is display g code on an PyQt QtOpenGLWidget... I think I should be using the glcanon.py from lib/python/rs274... but not sure. I've been thrashing around for a couple of weeks and have not made any progress. If someone has a clue please let me know.
JT
help(gcode)
calc_extents(...)
Calculate information about extents of gcode
parse(...)
Parse a G-Code fileNot much help there...
>>> gcode.parse()
File "<stdin>", line 1, in <module>
TypeError: parse() takes at least 2 arguments (0 given)grepping I find this example in src/emc/usr_intf/axis/scripts/axis.py:1589:
result, seq = gcode.parse("", canon, "M199 P["+e+"]", "M2")>>> gcode.calc_extents()
([9e+99, 9e+99, 9e+99], [-9e+99, -9e+99, -9e+99], [9e+99, 9e+99, 9e+99], [-9e+99, -9e+99, -9e+99])So what I'm trying to do is display g code on an PyQt QtOpenGLWidget... I think I should be using the glcanon.py from lib/python/rs274... but not sure. I've been thrashing around for a couple of weeks and have not made any progress. If someone has a clue please let me know.
JT
Last edit: 25 May 2024 16:16 by JT.
- Thank you received: 2181
25 May 2024 16:41 #301418
Replied by cmorley on topic Python gcode.parse and gcode.calc_extents
Have you looked at gremlin/qt_graphics?
25 May 2024 17:30 #301421
Replied by andypugh on topic Python gcode.parse and gcode.calc_extents
By coincidence I found an example of the use of gcode.parse in a post I replied to earlier today:
forum.linuxcnc.org/38-general-linuxcnc-q...code-preview-as-json
- JT
25 May 2024 18:08 #301426
by JT
Replied by JT on topic Python gcode.parse and gcode.calc_extents
I have looked st gremlin/qt5_graphics.py and will look closer at it.
JT
JT
- JT
25 May 2024 18:21 #301427
by JT
Actually I just ran gremlin/qt5_graphics.py with Axis running and other than the offsets not being used it plots, just need to figure out how to use it in my GUI.
JT
JT
- Thank you received: 2176
25 May 2024 18:21 #301428
Replied by Aciera on topic Python gcode.parse and gcode.calc_extents
IIRC .parse will run the gcode and create lists of line segments for 'traverse', 'straight_feed' and 'arc_feed' moves while .calc_extents will then find the minimum and maximum coordinates values from those lists.
This is from lib/python/rs274/glcanon.py:
which calls the pyobject in src/emc/rs274ngc/gcodemodule.cc:
Moderators: JT
Time to create page: 0.158 seconds
