Flex GUI Import a Python Module
- JT
- Thank you received: 593
07 Nov 2024 15:02 #314019
by JT
Flex GUI Import a Python Module was created by JT
Flex as of this morning can import a python module located in the configuration directory. Now you can have a lot more options and control over your GUI. This is so huge I didn't want it to get buried in the Flex Tutorials thread.
JT
JT
The following user(s) said Thank You: tommylight, digiex_chris
- JT
09 Nov 2024 20:04 #314140
by JT
Replied by JT on topic Flex GUI Import a Python Module
And for you probe fans Flex can now get user parameter values on startup and change them from the GUI.
Quite a few folks on the IRC use Flex GUI.
Is anyone here using Flex GUI?
JT
JT
- digiex_chris
- Thank you received: 11
17 Nov 2024 02:23 - 17 Nov 2024 02:24 #314637
by digiex_chris
Replied by digiex_chris on topic Flex GUI Import a Python Module
I am, which IRC are you referring to? I'll join up!
edit: oops, found it! on the community page of linuxcnc
Last edit: 17 Nov 2024 02:24 by digiex_chris.
- JT
17 Nov 2024 12:14 #314656
by JT
JT
There is also the #flex-deb channel on Libera.Chat for bug reports or feature requests.I am, which IRC are you referring to? I'll join up!
JT
- JT
25 Nov 2024 13:51 - 25 Nov 2024 13:52 #315236
by JT
Flex now has a user timer that can be used in the user python module.
JT
JT
Last edit: 25 Nov 2024 13:52 by JT.
Moderators: JT
Time to create page: 0.136 seconds
