Flex GUI Hole Ops
- JT
- Thank you received: 593
23 Nov 2024 14:34 - 24 Nov 2024 14:30 #315107
by JT
Flex GUI Hole Ops was created by JT
Hole operations using parameters set from the GUI in subroutines.
JT
JT
Last edit: 24 Nov 2024 14:30 by JT. Reason: Update the url
- Thank you received: 7484
24 Nov 2024 22:44 #315194
Replied by tommylight on topic Flex GUI Hole Ops
Nicely done, maestro.
Thank you.
Thank you.
- JT
25 Nov 2024 00:53 #315206
by JT
Replied by JT on topic Flex GUI Hole Ops
Actually Tom from the IRC programmed the subroutines and made that GUI I just gave him the tools to do the job. Flex GUI is getting to be quite flexible and powerful. I like to think of Flex GUI is like LinuxCNC you can do anything you can think of and you're not forced to use what some programmer thinks you need.
JT
JT
Moderators: JT
Time to create page: 0.072 seconds
