Flex GUI Themes
- JT
- Thank you received: 593
13 Dec 2024 14:05 #316577
by JT
Flex GUI Themes was created by JT
I've added a few themes to Flex GUI. Notice the nice arrows on the spin boxes.
Blue Theme
Dark Theme
Blue Touch Screen Theme
Dark Touch Screen Theme
To add a theme you just add an ini entry.
gnipsel.com/linuxcnc/flexgui/ini.html#themes
JT
Blue Theme
Dark Theme
JT
The following user(s) said Thank You: tlightus, tommylight
- blazini36
- Thank you received: 167
03 Jan 2025 22:59 #317979
by blazini36
Replied by blazini36 on topic Flex GUI Themes
Very cool, this looks like it's coming along nicely and you're even taking the time to write the documentation. Hopefully I'll get back around to my control panel project so I can dig into this.Any suggestion what example would be a good place to start for a control panel like this, where it has a touch screen but would mostly use physical controls? This would be for a small mill (3 axis with 4th) and I currently do toolsetting on change with Gmoccapy
- JT
04 Jan 2025 14:22 #318071
by JT
Replied by JT on topic Flex GUI Themes
That's best part about the Flex GUI you can put what YOU want/need in the GUI. I would think you can build the GUI you want in just a few minutes. BTW, there is a series of videos on Flex GUI. www.youtube.com/@Gnipsel/playlists
JT
JT
- blazini36
06 Jan 2025 04:34 #318189
by blazini36
It's always hard to get started with something like this, starting from an example is generally easier but I think I'll start from scratch. I'll throw some questions at a more general post about flex....don't wanna clog up this one.That's best part about the Flex GUI you can put what YOU want/need in the GUI. I would think you can build the GUI you want in just a few minutes. BTW, there is a series of videos on Flex GUI. www.youtube.com/@Gnipsel/playlists
- JT
08 Jan 2025 15:18 - 08 Jan 2025 15:20 #318416
by JT
Last edit: 08 Jan 2025 15:20 by JT.
Moderators: JT
Time to create page: 1.158 seconds
