FlexGui -Touch off
- MaHa
- Thank you received: 240
16 Sep 2025 09:23 - 16 Sep 2025 11:13 #335058
by MaHa
FlexGui -Touch off was created by MaHa
It seems i am attracting 'touch off' troubles. Still working on my UI. After run from terminal,homing,loading a g-code file and then press touch off button (touchoff_selected_pb) , linuxcnc shuts down with an error. At least there is some info printed in the terminal. This is from the flex_examples axis:
Found file(REL): ./main.hal
File "/usr/lib/python3/dist-packages/PyQt6/uic/ui_file.py", line 35, in __init__
document = ElementTree.parse(ui_file)
File "/usr/lib/python3.11/xml/etree/ElementTree.py", line 1218, in parse
tree.parse(source, parser)
File "/usr/lib/python3.11/xml/etree/ElementTree.py", line 569, in parse
source = open(source, "rb")
FileNotFoundError: [Errno 2] Datei oder Verzeichnis nicht gefunden: '/home/miller/linuxcnc/configs/flex_examples/touchoff.ui'
During handling of the above exception, another exception occurred:
File "/usr/lib/python3/dist-packages/libflexgui/dialogs.py", line 70, in touchoff_selected
to = touchoff.app()
File "/usr/lib/python3/dist-packages/libflexgui/touchoff.py", line 22, in __init__
loadUi(to_ui_path, self)
File "/usr/lib/python3/dist-packages/PyQt6/uic/load_ui.py", line 86, in loadUi
return DynamicUILoader(package).loadUi(uifile, baseinstance)
File "/usr/lib/python3/dist-packages/PyQt6/uic/Loader/loader.py", line 62, in loadUi
return self.parse(filename)
File "/usr/lib/python3/dist-packages/PyQt6/uic/uiparser.py", line 995, in parse
ui_file = UIFile(filename)
File "/usr/lib/python3/dist-packages/PyQt6/uic/ui_file.py", line 37, in __init__
self._raise_exception("invalid Qt Designer file", detail=str(e))
File "/usr/lib/python3/dist-packages/PyQt6/uic/ui_file.py", line 92, in _raise_exception
raise UIFileException(self._ui_file, message, detail=detail)
PyQt6.uic.exceptions.UIFileException: /home/miller/linuxcnc/configs/flex_examples/touchoff.ui: invalid Qt Designer file: [Errno 2] Datei oder Verzeichnis nicht gefunden: '/home/miller/linuxcnc/configs/flex_examples/touchoff.ui'
/usr/bin/linuxcnc: Zeile 977: 2156382 Abgebrochen $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
Warning: Spoiler!
to = touchoff.app()
Last edit: 16 Sep 2025 11:13 by MaHa. Reason: typos
- JT
- Thank you received: 593
20 Sep 2025 21:14 #335222
by JT
That is an installed file not one that is in the configs directory so it makes me think your not running flex from linuxcnc.
JT
Replied by JT on topic FlexGui -Touch off
By run from terminal do you mean you launched flexgui from a terminal or linuxcnc?It seems i am attracting 'touch off' troubles. Still working on my UI. After run from terminal,homing,loading a g-code file and then press touch off button (touchoff_selected_pb) , linuxcnc shuts down with an error. At least there is some info printed in the terminal. This is from the flex_examples axis:
Warning: Spoiler!
to = touchoff.app()
JT
- MaHa
20 Sep 2025 23:45 #335229
by MaHa
Replied by MaHa on topic FlexGui -Touch off
I start linuxcnc from terminal, then select the ui to start. I just tested again. Running a program with subroutine or without.
after finish, use the jog buttons to move xyz position. Then touch off button shuts down linuxcnc with this error.
This happens only when jog to another position and trying to touch off,after a gcode was running. On a new started ui is no problem
- MaHa
21 Sep 2025 21:25 - 21 Sep 2025 21:51 #335252
by MaHa
I had time for some investigation. When touchof before running a gcode, (self.gui_path) in the file touchoff.py leads to /usr/lib/libflexgui. but after running a gcode (self.gui_path) contains /home/miller/linuxcnc/configs.
Toolchange popup is affected also the same way.
Last edit: 21 Sep 2025 21:51 by MaHa.
- JT
22 Sep 2025 19:13 #335301
by JT
JT
Thanks for investigating this, this is a big help. I'll get this fixed ASAP.I had time for some investigation. When touchof before running a gcode, (self.gui_path) in the file touchoff.py leads to /usr/lib/libflexgui. but after running a gcode (self.gui_path) contains /home/miller/linuxcnc/configs.
JT
The following user(s) said Thank You: MaHa
Moderators: JT
Time to create page: 0.202 seconds
