FlexGui - View setting error
  • MaHa
  • Topic Author
  • Platinum Member
  • Platinum Member
1 year 4 weeks ago #336069 by MaHa
FlexGui - View setting error was created by MaHa
Today, after update there is this error preventing start. When this entry is present in the .ini file
[DISPLAY] VIEW = x
thats printed in terminal. If i comment that entry, the ui starts
  File "/usr/bin/flexgui", line 313, in <module>     window = flexgui()              ^^^^^^^^^   File "/usr/bin/flexgui", line 229, in __init__     startup.setup_jog(self)   File "/usr/lib/python3/dist-packages/libflexgui/startup.py", line 1167, in setup_jog     if parent.jog_increments:        ^^^^^^^^^^^^^^^^^^^^^ AttributeError: 'flexgui' object has no attribute 'jog_increments' Shutting down and cleaning up LinuxCNC...
A question about the plotter i was going to ask anyway: If a program is loaded, machine zero is in the center of the plot, and i have to search the preview. Is there a way to have the current coordinate system zero, centered in the plot, to see the preview directly.
Thanks for all the work done in this project. At the moment i am integrating the subroutines, and it's really nice how to control the index of tabs and stacked widget with a button connected to some python, then load the program with a push button.
  • MaHa
  • Topic Author
  • Platinum Member
  • Platinum Member
1 year 4 days ago #337767 by MaHa
Replied by MaHa on topic FlexGui - View setting error
The view setting is not really necessary, as somehow machine zero is centered at startup. So i removed the ini entry. After loading gcode, the desired view can be selected, and then its centered in the preview. So i solved this by finding my workflow
1 year 3 days ago #337809 by JT
Replied by JT on topic FlexGui - View setting error
[DISPLAY] VIEW = x thats printed in terminal. If i comment that entry, the ui starts [code]  File "/usr/bin/flexgui", line 313, in <module>     window = flexgui()              ^^^^^^^^^   File "/usr/bin/flexgui", line 229, in __init__     startup.setup_jog(self)   File "/usr/lib/python3/dist-packages/libflexgui/startup.py", line 1167, in setup_jog     if parent.jog_increments:        ^^^^^^^^^^^^^^^^^^^^^ AttributeError: 'flexgui' object has no attribute 'jog_increments' Shutting down and cleaning up LinuxCNC... A question about the plotter i was going to ask anyway: If a program is loaded, machine zero is in the center of the plot, and i have to search the preview. Is there a way to have the current coordinate system zero, centered in the plot, to see the preview directly. Thanks for all the work done in this project. At the moment i am integrating the subroutines, and it's really nice how to control the index of tabs and stacked widget with a button connected to some python, then load the program with a push button.
[/code]
I've not figured out how to move the plot in code. I don't get that error so I must have fixed it.
JT
Moderators: JT
Time to create page: 0.054 seconds
