Disable pushbutton
  • MaHa
  • Topic Author
  • Platinum Member
  • Platinum Member
10 months 1 week ago #340628 by MaHa
Disable pushbutton was created by MaHa
I am looking at disable a pushbutton during program runtime. No idea how to do. It is connected to python module, and should not
be enabled during runtime. Is there a setting, it gets greyed out, eg. like mdi-button?
  • MaHa
  • Topic Author
  • Platinum Member
  • Platinum Member
10 months 1 week ago #340634 by MaHa
Replied by MaHa on topic Disable pushbutton
With function mdi and command M66E0L0 the button is disabled while running a program and that doesn't affect its initial functionality. But still hoping there is another way to do that.
10 months 1 week ago #340635 by JT
Replied by JT on topic Disable pushbutton
Let me verify how to do that, it should be simple but I want to test first.
JT
10 months 1 week ago #340656 by JT
To have a button with an object name of state_stop_pb be disabled when the estop is on and enabled when the estop is off.
parent.state_estop_pb.setEnabled(False) parent.state_estop['state_estop_pb'] = False parent.state_estop_reset['state_estop_pb'] = True
To have a button with the object name of state_on be off when the power is off
parent.state_on_pb.setEnabled(False) parent.state_estop_reset['state_on_pb'] = False parent.state_on['state_on_pb'] = True
And to answer your question to have a button disabled when a program is running add the object name to the following dictionaries
parent.state_on['disabled_running_pb'] = True parent.program_running['disabled_running_pb'] = False
JT
The following user(s) said Thank You: MaHa
  • MaHa
  • Topic Author
  • Platinum Member
  • Platinum Member
10 months 1 week ago #340668 by MaHa
That was easy to do, and it works exactly as desired. It is important for me to lock out this kind of potential risks.
Thank you for providing this information.
Moderators: JT
Time to create page: 0.156 seconds
