Jog troubles
25 Mar 2026 07:21 #344700 by ts
Jog troubles was created by ts
JT, hi. Its me again for today)
I have Cnc machine with axis - xyz and C. (C because it is rotated around Z axis).
when im powerup the machine and starting jogging it, i have to use axis C as axis for jog number 3 - jog_plus_pb_3. But after homingĀ  that axis became axis number 5. And after homing i have to use jog_plus_pb_5.
It is strange, and i found only that i could block jogging button for C axis until homing is conpleted. Is there any more flex solutolions for this issue?)
Thanks in advance!
TS
27 Mar 2026 18:42 #344839 by JT
Replied by JT on topic Jog troubles
That's a LinuxCNC issue the joints are numbered 0-8 for xyzabcuvw so c is joint 5.
Maybe a jog axis button would work. I'd have to test.
JT
28 Mar 2026 00:18 #344852 by rodw
Replied by rodw on topic Jog troubles
why jog before homing? I always disable it.
28 Mar 2026 03:10 #344865 by ts
Replied by ts on topic Jog troubles
Yes, it will work. But only after homing.
Before homing its work as 3rd number (all axus numbers are 0-1-2-3 )
28 Mar 2026 03:14 #344866 by ts
Hi, Rodw! Glad to see you in this topic)
Jog before homing.. hmmm.. for example, edm machine , some emergency, estop pressed or power loss.. and mechanical of the machine stucked. I have to move before homing, because homing may broke everything on the work table
28 Mar 2026 10:57 #344872 by JT
The following is the Python interface so it forces you to use joint number before homing then use index of axis after homing.
    joint_num_or_axis_index
        For joint jog (jjogmode=1)
            joint_number
        For axis Cartesian coordinate jog (jjogmode=0)
            zero-based index of the axis coordinate with respect to the known coordinate letters XYZABCUVW (x=>0,y=>1,z=>2,a=>3,b=>4,c=>5,u=>6,v=>7,w=>8)
JT
Moderators: JT
Time to create page: 0.103 seconds
