PLOT/grid_size
22 Oct 2026 18:45 - 23 Oct 2026 18:08 #350417 by MaHa
PLOT/grid_size was created by MaHa
After update i am not able to run my flex ui
File "/usr/bin/flexgui", line 547, in window = flexgui() File "/usr/bin/flexgui", line 393, in __init__ startup.setup_plotter(self) ~~~~~~~~~~~~~~~~~~~~~^^^^^^ File "/usr/lib/python3/dist-packages/libflexgui/startup.py", line 3615, in setup_plotter set_grid_size = parent.settings.value('PLOT/grid_size', default_grid_size, type=float) ^^^^^^^^^^^^^^^^^ UnboundLocalError: cannot access local variable 'default_grid_size' where it is not associated with a value Shutting down and cleaning up LinuxCNC...
Edit:
It's just my testing in virtualbox, so no problem. Flex examples crash also
Last edit: 23 Oct 2026 18:08 by MaHa.
Moderators: JT
