Configure Control Pendant P4-S - iMach3
  • jstoquica
  • jstoquica's Avatar Topic Author
  • Premium Member
  • Premium Member
27 Oct 2015 20:47 #64366 by jstoquica
Configure Control Pendant P4-S - iMach3 was created by jstoquica
Good Day,
Recently I buy a Control Pendant to use with my retrofitting project. The robot is not yet operating, but I would use the pendant for teaching, in the vismach simulation for now.
I want to configure the pendant for working with linuxcnc. This is the descrption of the device:
At the developer site, I can download config files for linuxcnc (99-vistacnc-pendant.rules, Makefile, vc-p4s, vc-p4s.hal). And some instructions for install the files. I attached them.
When I want to test with a some linuxcnc config example like Puma560, but some errors was generated:
libusb couldn't open USB deivce /dev/bus/usb/008/002: permission denied.
libusb requires write access to USB devices nodes.
vc-p4s.hal:74: Pin 'halui.mdi-command-05' does not exist
I did my config simulation in RIP mode, therefore I have to work in root mode. Will I try to work in my config folder (RIP mode) for test the pendant, or I can test and configure in normal user mode?
Thanks and regards.
28 Oct 2015 00:09 - 28 Oct 2015 06:14 #64374 by dgarrett
Replied by dgarrett on topic Configure Control Pendant P4-S - iMach3
You should not need to run as root if udev is configured for the device (running LinuxCNC as root can cause numerous hard-to-debug problems later).
for example, for the xhc-hb04 pendant, the udev rule is:
ATTR{idProduct}=="eb70", ATTR{idVendor}=="10ce", MODE="0666", OWNER="root", GROUP="plugdev"
Change the idProduct and idVendor as required for the device. You will then need to trigger udev
or reboot.
Ref:
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...0d;hb=refs/heads/2.7
the man page for udev gives some info on location for udev rules files:
$ man udev
RULES FILES
       The udev rules are read from the files located in the system rules directory /lib/udev/rules.d,
       the volatile runtime directory /run/udev/rules.d and the local administration directory
       /etc/udev/rules.d. All rules files are collectively sorted and processed in lexical order,
       regardless of the directories in which they live. However, files with identical filenames
       replace each other. Files in /etc have the highest priority, files in /run take precedence over
       files with the same name in /lib. This can be used to override a system-supplied rules file with
       a local file if needed; a symlink in /etc with the same name as a rules file in /lib, pointing
       to /dev/null, disables the rules file entirely. Rule files must have the extension .rules; other
       extensions are ignored.
Last edit: 28 Oct 2015 06:14 by dgarrett. Reason: add udev man page info
The following user(s) said Thank You: jstoquica
  • jstoquica
  • Premium Member
  • Premium Member
25 Nov 2015 17:32 #65805 by jstoquica
Replied by jstoquica on topic Configure Control Pendant P4-S - iMach3
Thanks for your answer.
I had to update the firmware of the pendant, and as you said copy the rules at right locations. After that the simulation was a success, with cnc machines and Puma configuration.
Now for my own manipulator (Run In Place Mode) configurations I have doubts:
In normal LinuxCNC mode I did the next:
2. Copy and move files to LinuxCNC PC
Makefile
vc‐p4s
vc‐p4s.hal
99‐vistacnc‐pendant.rules
3. Put Makefile, vc‐p4s and 99‐vistacnc‐pendant.rules to “src” under home directory ~/src$. If
there is a Makefile in that directory, name that make file to different name, like Makefile_old.
4. Run make install , this will install vc‐p4s to /usr/bin and 99‐vistacnc‐pendant.rules to
/lib/udev/rules.d
5. Put vc‐p4s.hal to your config directory, the same directory as .ini file.
6. add lines to .ini files:
[HAL]
HALFILE = my­mill.hal
HALFILE = vc­p4s.hal
POSTGUI_HALFILE = custom_postgui.hal
HALUI = halui
[HALUI]
MDI_COMMAND=...
MDI_COMMAND=...
MDI_COMMAND=...
MDI_COMMAND=...
MDI_COMMAND=...
MDI_COMMAND=G10 L20 P1 X0
MDI_COMMAND=G10 L20 P1 Y0
MDI_COMMAND=G10 L20 P1 Z0
MDI_COMMAND=G0 X0 Y0 Z0
MDI_COMMAND=G10 L20 P1 A0
MDI_COMMAND=G10 L20 P1 B0
MDI_COMMAND=G10 L20 P1 C0
o Makefile has:
CFLAGS=-I/usr/include/linuxcnc
all:    vc-p4s
vc-p4s: vc-p4s.cc
        g++ $(CFLAGS) vc-p4s.cc -o $@ -lusb-1.0 -lm -llinuxcnchal -llinuxcncini
install:
        sudo install -m 0755  -g root -o root vc-p4s /usr/bin
        sudo install -m 0755  -g root -o root 99-vistacnc-pendant.rules /lib/udev/rules.d
Then, how can I control my own manipulator configs in RIP mode compatible with the pendant? When I talking about RIP mode is when I have the source file and I add kinematics files for a new manipulator conf like Puma560 and some folders are diferents like /lib/.... or usr/include ....
RIP envioroment with source file Linuxcnc 2.5.0:
cd src
In the source directory, build LinuxCNC:
./autogen.sh  (this builds the configure script)
./configure --enable-run-in-place
make clean
make
sudo make setuid
to run the software go back to the top level directory, and issue:
scripts/. rip-environment
linuxcnc
Thanks a lot.
25 Nov 2015 18:08 #65807 by dgarrett
I'm not sure i understand the question but:
presumes that LinuxCNC is installed (a DEB install) on the system.
This might work with a RIP build if you have _both_ a git tree for RIP
and a _compatible_ DEB installed simultaneously. If you ever get the
RIP install and the DEB install out-of-sync, there will be some
hard-to-identify problems.
For use exclusively with a RIP install, the line would probably be
something like:
CFLAGS=-I/the_path_to_your_top_git_dir/include
  • jstoquica
  • Premium Member
  • Premium Member
22 Mar 2016 15:37 - 22 Mar 2016 15:37 #72052 by jstoquica
It's true, I compile the entire Linuxcnc without rip mode, directly at /usr/.
cd src
.autogen.sh
./configure --prefix=/usr
make clean
make
sudo make setuid
Thanks.
Last edit: 22 Mar 2016 15:37 by jstoquica.
20 Jan 2017 21:23 #86333 by Jake
Replied by Jake on topic Configure Control Pendant P4-S - iMach3
Have you gotten to where you can use the pendant yet? How do you like it?
Time to create page: 0.294 seconds
