Getting soft limits to work without homing
- terkaa
- Thank you received: 3
30 Aug 2016 19:39 #79740
by terkaa
Getting soft limits to work without homing was created by terkaa
I use abs encoders so no homing will be done. I would still like to be able to use soft limits. I found this from command.c :
void refresh_jog_limits(emcmot_joint_t *joint)
double range;
if (GET_JOINT_HOMED_FLAG(joint)) {
/* if homed, set jog limits using soft limits */
joint->max_jog_limit = joint->max_pos_limit;
joint->min_jog_limit = joint->min_pos_limit;
} else {
/* not homed, set limits based on current position */
range = joint->max_pos_limit - joint->min_pos_limit;
joint->max_jog_limit = joint->pos_fb + range;
joint->min_jog_limit = joint->pos_fb - range;
If I change this to:
/* Set jog limits using soft limits */
Would that "do the trick"?
Tero
double range;
} else {
Tero
01 Sep 2016 16:40 #79844
It might, until the next LinuxCNC update...
Replied by andypugh on topic Getting soft limits to work without homing
- terkaa
01 Sep 2016 17:33 #79853
by terkaa
Replied by terkaa on topic Getting soft limits to work without homing
Ok, I would like to try. What is make line only for compiling and installing parts related to command.c ?
Tero
Tero
01 Sep 2016 20:12 #79871
I don't know, I have never tried compiling anything bigger than a HAL module or smaller than the entire source tree.
- terkaa
01 Sep 2016 20:27 #79876
by terkaa
Ok, I did compile the whole thing but trying to run sudo make install tells me "configured with run-in-place" configure without run-in-place. How do I disable run in place?
Tero
Tero
02 Sep 2016 10:22 - 02 Sep 2016 10:22 #79897
It's probably best to try it out with run-in-place first.
(Open a terminal, then
I still think you should run master. As far as I recall the absolute homing feature was added for you.
. ./linuxcnc-dev/scripts/rip-environment
LinuxcncI still think you should run master. As far as I recall the absolute homing feature was added for you.
Last edit: 02 Sep 2016 10:22 by andypugh.
- terkaa
02 Sep 2016 10:53 - 02 Sep 2016 11:02 #79900
by terkaa
I did try it with RIP and it does work. Originally my idea was to tweak source so that when NO_FORCE_HOMING=1 then soft limits would be tied to pos-fb and if NO_FORCE_HOMING = 0 the offset+pos-fb. Yes I understand your point of view and I will try 2.8 after I receive another similar PC. But you also have to see my point of view: After I get everything installed and working this machine will be ran 3 shifts per day in a machining shop. It will be ran by our CNC-machinists.(not by me) + Given the fact that I made the decision to install LinuxCNC instead of Fanuc. So I am not very eager to run untested software in this environment where machine users are in risk to get injured if something goes wrong(Also it will be on my responsibility). + If users have to deal with bugs they will request me to replace control with Fanuc. Also it is very nice to hear that this feature was added for our application but I did not request that. I requested SSI+sserial firmware for 5i25 and I am happy to have that. But yes I will try out 2.8 and report bugs if I see em. If it does seem to work we may even stick with it. But it is good to have a backup plan, in this case 2.7.6 with minor source mod.
Tero
Tero
Last edit: 02 Sep 2016 11:02 by terkaa.
02 Sep 2016 18:11 #79918
Sorry, I didn't mean to sound like I was trying you guilt-trip you into trying 2.8.
And it wasn't you anyway, it was this chap.
forum.linuxcnc.org/forum/38-general-linu...imits-for-axes#74605
- terkaa
02 Sep 2016 18:17 #79920
by terkaa
Oh I see
I have been thinking about building a mini mill (X=250mm Y= 150mm Z=100mm) This would run LinuxCNC with Mesa cards and Fagor SSI absolute encoders. It would be nice to have in my garage, and would act as a very good test platform.
Tero
Tero
- Thank you received: 7488
02 Sep 2016 20:58 #79936
Replied by tommylight on topic Getting soft limits to work without homing
Something like this ?
Time to create page: 0.873 seconds
