× Forum Header
Why appears the error?
14 Jan 2014 22:51 #42769 by BosniaCNC
Why appears the error? was created by BosniaCNC
Why not EMC2 boot after completing the configuration?
14 Jan 2014 23:34 - 14 Jan 2014 23:35 #42772 by ArcEye
Replied by ArcEye on topic Why appears the error?
Hi
No idea, need more information, especially the end of the 'Kernel message Information'
zip your config folder and attach it and attach the resultant dmesg.txt file from running
dmesg > dmesg.txt in a terminal
Last edit: 14 Jan 2014 23:35 by ArcEye.
The following user(s) said Thank You: BosniaCNC
19 Jan 2014 04:26 #42989 by BosniaCNC
Replied by BosniaCNC on topic Why appears the error?
My dear friend and I have no idea why the error!Text messaging is not saved on disk.Unable to save the message to disk!
I enclose a picture and a zip file, from which it is possible to see an error message.
File Name: linuxcnc.tar.gz
File Size:209 KB
19 Jan 2014 04:39 #42992 by PCW
Replied by PCW on topic Why appears the error?
Can you type this in a terminal window:
dmesg > dmesg.txt
and post the file dmesg.txt here
There is not enough information to determine the error
without the full kernel log from dmesg
19 Jan 2014 04:50 #42994 by BosniaCNC
Here's a text message... :)
File Name: dmesg.txt.tar.gz
File Size:14 KB
19 Jan 2014 05:05 #42997 by PCW
The error is this:
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] APIC: disable apic facility
A possible solution is this:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl..._t_run_missing_lapic
19 Jan 2014 05:17 #42999 by BosniaCNC
Thanks for the help!
Time to create page: 0.179 seconds
