Forum Header
Impossible to set good value - 2.6.0
- Gloup
01 Aug 2014 19:38 #49395
by Gloup
Impossible to set good value - 2.6.0 was created by Gloup
Hello
I use LinuxCnc since 2.5.0 version and normally I solve all differents problems. But now it's a big mistake !
I have a milling machine 3 axis and I try to update it to the version 2.6.0 but I have some things impossible to update.
As you can see on the first attachment, I have to set a driver timming for my Leadshine driver. I select Other and I try to put the value. But at each time, the value return to 100ns !
Other attachement for the axix X, I have to set the velocitu and direction, but as you can see, the text is wrong. and I don't know what I have to do.
I hope somebody could help me to return to the good params. I think If there is a problem on the stepconf I can write directly the value on a file, but I don't know how to.
- Thank you received: 5219
01 Aug 2014 20:15 #49396
Replied by PCW on topic Impossible to set good value - 2.6.0
It seems broken on my system also (2.6pre5)
Do you actually need to run stepconf?
Dont your existing hal and ini files still work?
- Gloup
01 Aug 2014 20:26 - 01 Aug 2014 20:29 #49398
by Gloup
Replied by Gloup on topic Impossible to set good value - 2.6.0
I thinked I need it. I have backup my 2.5.4 config on a stick but I haven't test if I can launch it with 2.6 version. In my mind, I would start with a fresh installation because I change in the same time the computer, but I can try this evening.
Something sure, I developp an additionnal panel and it doesn't work, I have a load-time error. But It seems normal as I can read on the page to update. For the moment I just search to start up the machine.
Last edit: 01 Aug 2014 20:29 by Gloup.
- seb_kuzminsky
- Thank you received: 14
06 Aug 2014 02:37 #49539
by seb_kuzminsky
Replied by seb_kuzminsky on topic Impossible to set good value - 2.6.0
Fixed in 2.6.1, available as of this morning. Thanks for the bug report.
The following user(s) said Thank You: Gloup
Time to create page: 0.048 seconds
