FreeCAD g-code generator?
- mstrick96
21 Jan 2016 15:30 #68884
by mstrick96
FreeCAD g-code generator? was created by mstrick96
Has anyone worked with the Path Workbench in FreeCAD for generating g-code?
The developer says it is in early stages,mbut it looks like it has some interesting features already. Especially for making simple parts.
What do you think?
What do you think?
- emcPT
- Thank you received: 139
23 Jan 2016 10:19 #68957
by emcPT
Replied by emcPT on topic FreeCAD g-code generator?
Recently I found ECAM:
ecam.altervista.org/
The best free CAM that I know, and I tested it several times both for milling and lathe. Development is active and the postprocessor can be changed to suit for example linuxcnc.
The following user(s) said Thank You: mstrick96
- BigJohnT
- Thank you received: 1176
23 Jan 2016 20:47 #68998
by BigJohnT
Replied by BigJohnT on topic FreeCAD g-code generator?
For a lathe I do all that and more with ngcgui.
JT
JT
- mstrick96
23 Jan 2016 22:22 - 23 Jan 2016 22:25 #69006
by mstrick96
Replied by mstrick96 on topic FreeCAD g-code generator?
Thanks. Good info.
I'm building a longbed lathe and am thinking of adding a NC machining head to it later. Am most interested in building an NC router for woodworking and setting up a CAD/CAM/CAE workstation to do the design and control for both.
I like the looks of FreeCAD and am running it on a Debian 8.2 workstation with LinuxCNC. Am figuring out how to replace the Jessie kernel with a recent RT kernel and will then be set if the g-code in FreeCAD works well enough. If it doesn't work well, I'l try your suggestions.
Lots to learn!! Too many hobbies and not enough time!
Last edit: 23 Jan 2016 22:25 by mstrick96.
- BigJohnT
23 Jan 2016 23:08 #69007
by BigJohnT
Well ngcgui is part of Linuxcnc so it is seamless and fast to program any part. So that takes a step or three out of the process.
JT
JT
- mstrick96
24 Jan 2016 01:59 #69013
by mstrick96
Great! Looks like I have two options built in, then.
Thanks!
Thanks!
Time to create page: 0.056 seconds
