changing max velocity on startup
- jtc
- Thank you received: 12
13 Jul 2016 11:10 #77381
by jtc
changing max velocity on startup was created by jtc
- Thank you received: 2173
14 Jul 2016 03:11 #77424
Replied by cmorley on topic changing max velocity on startup
halui.max-velocity
using a switch requires using the direct-value option and a mux or somethimg similar
set the scaling to get percent, then have a mux component out put 25,50,100 % depending on the switch position.
Chris M
Chris M
- jtc
14 Jul 2016 20:23 #77458
by jtc
Replied by jtc on topic changing max velocity on startup
that was what I used, but, for example, if I left the machine on 25%, next time I start linuxcnc it will be set at 100%. only if I make a change on the switch it will update.
João
João
- BigJohnT
- Thank you received: 994
14 Jul 2016 21:38 #77465
by BigJohnT
Replied by BigJohnT on topic changing max velocity on startup
The pin halui.machine.is-on toggles when the power button (F2) is pressed. Maybe you can use this to toggle the logic.
JT
JT
The following user(s) said Thank You: jtc
Time to create page: 0.158 seconds
