Rebuilding a Hardinge CHNC Turret
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
25 Apr 2010 14:21 - 25 Apr 2010 14:29 #2697 by BigJohnT
Rebuilding a Hardinge CHNC Turret was created by BigJohnT
The first thing you need to do is take the cover off the big nut and remove it while the turret is down.
Last edit: 25 Apr 2010 14:29 by BigJohnT.
  • BigJohnT
  • Administrator
  • Administrator
25 Apr 2010 14:22 - 25 Apr 2010 14:32 #2698 by BigJohnT
Replied by BigJohnT on topic Re:Rebuilding a Hardinge CHNC Turret
Removing the dowel pins with a slide hammer... if you try an lift this part off without pulling up the dowel pins at least a 1/4" you will break one... wanna know how I know?
Last edit: 25 Apr 2010 14:32 by BigJohnT.
  • BigJohnT
  • Administrator
  • Administrator
25 Apr 2010 14:23 - 25 Apr 2010 14:35 #2699 by BigJohnT
Popping the piston out with 10psig of air and engaging the lift and spin solenoid.
Last edit: 25 Apr 2010 14:35 by BigJohnT.
  • BigJohnT
  • Administrator
  • Administrator
25 Apr 2010 14:24 - 25 Apr 2010 14:36 #2700 by BigJohnT
Down to the turret stop ratchet. Kinda nasty in there but no rust.
Last edit: 25 Apr 2010 14:36 by BigJohnT.
  • BigJohnT
  • Administrator
  • Administrator
25 Apr 2010 14:25 - 25 Apr 2010 14:37 #2701 by BigJohnT
Everyone out of the pool...
Last edit: 25 Apr 2010 14:37 by BigJohnT.
  • BigJohnT
  • Administrator
  • Administrator
25 Apr 2010 14:26 - 25 Apr 2010 14:40 #2702 by BigJohnT
Putting the bottom plate for the piston area. All o-rings lubed up with Molykote 55.
Last edit: 25 Apr 2010 14:40 by BigJohnT.
  • BigJohnT
  • Administrator
  • Administrator
25 Apr 2010 14:27 - 25 Apr 2010 14:44 #2703 by BigJohnT
Putting the piston back in. All the quad rings can be purchased from McMaster Carr just measure the id or od of the ring.
She gits up and spins now lol.
Last edit: 25 Apr 2010 14:44 by BigJohnT.
26 Apr 2010 06:24 #2718 by Rick G
Replied by Rick G on topic Re:Rebuilding a Hardinge CHNC Turret
Hello John,
Great job, and great documentation of the work. With that step by step no one should by shy about tackling the job if need be. Of course it helps to know you are there if trouble shows up!
Rick G
  • BigJohnT
  • Administrator
  • Administrator
26 Apr 2010 06:34 #2719 by BigJohnT
Hi Rick,
The only trouble I ran into taking it that far apart was getting the ratchet timed. What I had to do was assemble all but the tool plate then fire the lock then the lift and rotate to bring it into alignment. Release the air from the lift and rotate then install the tool plate. This got me into mechanical alignment. Then I just spun the magnet around the encoder till the correct number showed up in my HAL watch window and locked it down.
The following user(s) said Thank You: lavrgs
30 Mar 2024 21:34 #297258 by lavrgs
Replied by lavrgs on topic Re:Rebuilding a Hardinge CHNC Turret
I am at the point where I need to do this mechanical alignment. I am not sure exactly what needs to get aligned. I am able to raise the piston but it will not spin. Sounds like I need to unlock the stop and bring the turret around so the stop aligns...?
Time to create page: 0.487 seconds
