CamWorks Post Processor for Linuxcnc
- robh
- Thank you received: 24
04 Feb 2013 07:24 #29542
by robh
CamWorks Post Processor for Linuxcnc was created by robh
Works with LinuxCNC 2.4 +
Can Be found on Wiki Here
wiki.linuxcnc.org/cgi-bin/wiki.pl?Cam_Post
Download Links
Non Random machines
wiki.linuxcnc.org/uploads/linuxcnc-camworks.rar
Random Machines
wiki.linuxcnc.org/uploads/linuxcnc-camworks_random.rar
Functions Available:
3 axis Simultaneous (4 & 5 Index)
G43 Hight Compensation.
G40, G41 & G42 Cutter Compensation.
Hole Cycles: G81 G82 (Dwell Support), G83 & G73
Metric & Imperial (G21, G20).
Use with CAMWorks Only.
Rigid Tapping Support G33.1 XYZ K (right hand only)
Subprogram Support (CALL, SUB, ENDSUB)
Outputs in *.NGC saved File.
Coolant Modes (M08 Flood,M09 Off,M07 Mist, M50 Through Hole)
Boring Cycles Support (G85,G89)
Feedrate output in Units/Min?
M00, M01 Stopcode Support.
G10 L20 Support.
Axis Support, 4=A, 5=B indexing only
I have now added a version for machines with Random Arm Tool Change so Pre tool calls work and first tool is reloaded at end of program for rerun,
Also fixed below issues
Change Log: for 1.0.2
1, Fix XYZ values for drilling cycles when restarting program
2, Fix Plane selections.
3, Change name to linuxcnc
Change Log: for 1.0.1
Fix Dwell output on Spot drilling 0.2 in cam now posts as 0.2sec.
Change N numbers from all lines to Tool change lines only.
Fix Reigid tapping output - mainly code tiddy up.
tiddy up some code output.
Fix rotary output to output sign value on - index positions.
Download Links
Non Random machines
Random Machines
G10 L20 Support.
The following user(s) said Thank You: cncbasher, biqut2, PKM, Sadmeatball
- cncbasher
- Thank you received: 202
07 Feb 2013 02:39 #29721
by cncbasher
Replied by cncbasher on topic CamWorks Post Processor for Linuxcnc
anyone have files or a starter source for a Lathe version for linuxcnc .
- PKM
11 Apr 2013 18:49 #32559
by PKM
Replied by PKM on topic CamWorks Post Processor for Linuxcnc
Thanks a lot for the post!
Is it possible to enable 5axis milling? What should be done for that?
- robh
12 Apr 2013 01:57 #32588
by robh
was doing a turning one, and a turn/mill one
at the moment i use a fanuc one and mod it by hand todo what i want, as never very complex on the lathe.
Replied by robh on topic CamWorks Post Processor for Linuxcnc
i did start making one but got side tracked on other thingsanyone have files or a starter source for a Lathe version for linuxcnc .
- robh
12 Apr 2013 01:59 #32589
by robh
i think it might already be on i cant rember just i have no tested it out as not had a need to use it yet properly
try i tout and let me know what does or does not work and i can make the mods hopefully.
source file should be in the zip file too if you wish to try sort it your self
- remrendes
23 Jul 2016 17:09 #77889
by remrendes
Replied by remrendes on topic CamWorks Post Processor for Linuxcnc
Hi!
Where can I get a *.CTL file for CW 2016?
- 10K
- Thank you received: 33
16 Nov 2017 15:03 #101897
by 10K
Replied by 10K on topic CamWorks / Solidworks CAM Post Processor for Linuxcnc Mill
I'm also looking for a Lathe version of the LinuxCNC Post Processor for Solidworks CAM (which is CamWorks 2.5D). I asked Solidworks, and they suggested that I either pay them $750 to make one, or write it myself with UPG. They won't provide the SRC file for the LinuxCNC mill post processor that they already have as a go-by, and I have been unable to locate anything online.
Has anyone made any progress on this, or is there something that I could use to start with other than a blank slate and UPG?
- biqut2
- Thank you received: 5
25 Feb 2021 21:01 - 25 Feb 2021 21:08 #200129
by biqut2
Replied by biqut2 on topic CamWorks / Solidworks CAM Post Processor for Linuxcnc Mill
I have one that I use on my 2 axis lathe. As mentioned before standard lathe isn't too complex. Can almost run the fanuc post as is.
Edit: Oops: didn't realize how old this was.
Last edit: 25 Feb 2021 21:08 by biqut2.
Time to create page: 0.244 seconds
