Mill Tapping G code Generator
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
11 Aug 2013 04:38 - 12 Aug 2013 17:55 #37549 by BigJohnT
Mill Tapping G code Generator was created by BigJohnT
I just cobbled up a python script to generate G code for drilling and tapping on a mill. Remove the .txt from the file name before using. If you open this up in Axis you can send the code directly to Axis.
NOTE: we are working on adding metric support so for now don't try using metric in units as it will be wrong.
JT
Last edit: 12 Aug 2013 17:55 by BigJohnT.
The following user(s) said Thank You: Mike_Eitel, AlexN
  • BigJohnT
  • Administrator
  • Administrator
12 Aug 2013 02:52 - 12 Aug 2013 17:53 #37570 by BigJohnT
Replied by BigJohnT on topic Mill Tapping G code Generator
Version 0.3.0 Added some more goodies. Metric still not fully functional. If someone wants to convert the dictionary from inch to mm this would complete this app.
Version 0.1.0 added metric drill sizes but dictionary needs converting
Version 0.2.0 added support for G83
Version 0.3.0 added F1 key binding to the help screen and changed the Tkinter import
        # Metric Drills change inch drills and pitch to metric and your set
        # tap size, pitch, 75% drill, 75% drill diameter, 50% drill for steel, 50% dia
        self.NF_TapM = {1:'#6-40,0.6350,M2.9,2.9,M3,3.0',
                      2:'#8-36,0.02778,#29,0.136,#26,0.147',
                      3:'#10-32,0.03125,#21,0.159,#18,0.169',
                      4:'#12-28,0.03571,#14,0.182,#10,0.1935',
                      5:'1/4-28,0.03571,#3,0.213,#1,0.228',
                      6:'5/16-24,0.04167,I,0.272,9/32,0.2812',
                      7:'3/8-24,0.4167,Q,0.332,S,0.348',
                      8:'7/16-20,0.0500,25/64,0.3906,13/32,0.4062',
                      9:'1/2-20,0.5000,29/64,0.4531,15/32,0.4688',
                     10:'9/16-18,0.5556,33/64,0.5156,17/32,0.5312',
                     11:'5/8-18,0.5556,37/64,0.5781,19/32,0.5938'}
        self.NC_TapM = {1:'#6-32,0.7937,M2.7,2.7,M2.9,2.9',
                      2:'#8-32,0.03125,#29,0.136,#27,0.144',
                      3:'#10-24,0.04167,#25,0.1495,#20,0.161',
                      4:'#12-24,0.04167,#16,0.177,#12,0.189',
                      5:'1/4-20,0.05000,#7,0.201,7/32,0.2188',
                      6:'5/16-18,0.05556,F,0.257,J,0.277',
                      7:'3/8-16,0.06250,5/16,0.3125,Q,0.332',
                      8:'7/16-14,0.07143,U,0.368,25/64,0.3906',
                      9:'1/2-13,0.07692,27/64,0.4219,29/64,0.4531',
                     10:'9/16-12,0.08333,31/64,0.4844,33/64,0.5156',
                     11:'5/8-11,0.09091,17/32,0.5312,9/16,0.5625'}
        self.M_TapM = {1:'M3.5-0.6,0.6000,M2.9,2.9,M3.0,3.0',
                      2:'M4-0.7,0.02756,#30,0.1285,#28,0.1405',
                      3:'M5-0.8,0.03150,#19,0.166,#16,0.177',
                      4:'M6-1.0,0.03937,#8,0.199,#4,0.209',
                      5:'M8-1.25,0.04921,H,0.266,J,0.277',
                      6:'M10-1.5,0.05906,R,0.339,T,0.358',
                      7:'M12-1.75,0.06890,13/32,0.4062,27/64,0.4219',
                      8:'M14-2.0,0.07874,15/32,0.4688,1/2,0.500',
                      9:'M16-2.0,0.07874,35/64,0.5469,37/64,0.5781'}
JT
Last edit: 12 Aug 2013 17:53 by BigJohnT.
  • Dan Falck
  • Dan Falck's Avatar
  • Visitor
  • Visitor
12 Aug 2013 04:34 #37573 by Dan Falck
Replied by Dan Falck on topic Mill Tapping G code Generator
Hi John,
I couldn't download that last attachment. I got an error: "Internal Server Error" 404 error
I did download the earlier version, but for the life of me, couldn't input coordinates into your self.CordList Listbox.
I like the concept that you have going on.
  • BigJohnT
  • Administrator
  • Administrator
12 Aug 2013 17:53 - 13 Aug 2013 21:36 #37586 by BigJohnT
Dan,
To add an XY pair to the list box you start in the X Center box, type in a value then press Enter. This moves the focus to the Y Center box. Type in a value and press Enter, this adds the pair to the XY List and moves the focus back to the X Center box for the next entry pair.
This is an adaptation of my counter bore program and I've attached the latest version 0.3.2.
JT
Last edit: 13 Aug 2013 21:36 by BigJohnT.
The following user(s) said Thank You: Dan Falck
  • Dan Falck
  • Visitor
  • Visitor
13 Aug 2013 06:42 #37600 by Dan Falck
Thanks John. Got it going now.
Dan
  • BigJohnT
  • Administrator
  • Administrator
13 Aug 2013 21:36 - 14 Aug 2013 00:00 #37626 by BigJohnT
Latest one 0.3.4
JT
Last edit: 14 Aug 2013 00:00 by BigJohnT.
  • BigJohnT
  • Administrator
  • Administrator
14 Aug 2013 00:01 - 14 Aug 2013 00:02 #37630 by BigJohnT
0.3.5 fixed a typo and an omission that caused an error if you left the peck depth field blank.
Last edit: 14 Aug 2013 00:02 by BigJohnT.
  • BigJohnT
  • Administrator
  • Administrator
14 Aug 2013 17:52 - 14 Aug 2013 17:53 #37657 by BigJohnT
Rob converted the metric dictionary last night so I'm adding metric fine and coarse to the generator. Oh and I'm adding G82 spot drill too.
JT
Last edit: 14 Aug 2013 17:53 by BigJohnT.
The following user(s) said Thank You: AlexN
  • BigJohnT
  • Administrator
  • Administrator
07 Jan 2015 21:30 - 08 Jan 2015 20:23 #54714 by BigJohnT
Fixed a strange one that made peck drilling fail to generate.
JT
Last edit: 08 Jan 2015 20:23 by BigJohnT.
The following user(s) said Thank You: library
11 Mar 2015 23:01 #56691 by library
Replied by library on topic Mill Tapping G code Generator
This was really helpful for my project today. Thanks for coding it up!
Moderators: Dan Falck
Time to create page: 0.235 seconds
