dxf2gcode
  • thor44
  • thor44's Avatar Topic Author
  • Premium Member
  • Premium Member
04 Nov 2013 04:32 #40521 by thor44
dxf2gcode was created by thor44
When I try running dxf2gcodeI get this error, does anyone know what I can do to make it work?
04 Nov 2013 06:56 #40529 by andypugh
Replied by andypugh on topic dxf2gcode
wiki.linuxcnc.org/cgi-bin/wiki.pl?Simple...e_and_produce_G_code
Explains that this is a separate package, and tells you where you can get it from.
Ask again if you have difficulty installing it.
  • thor44
  • Premium Member
  • Premium Member
06 Nov 2013 08:41 #40573 by thor44
Replied by thor44 on topic dxf2gcode
I think I missed something somewhere because it still wont work. When I download the file is there a certain place to save it or a place to extract it to? If so I'm not sure where that is, any help would be great. Does this program work very well? If not then maybe I wont bother with it.
06 Nov 2013 20:56 #40581 by andypugh
Probably usr/bin if you need it to be found automatically as a LinuxCNC filter.
06 Nov 2013 21:18 - 06 Nov 2013 21:35 #40584 by BigJohnT
Replied by BigJohnT on topic dxf2gcode
Another option is to use QCad.
linuxcnc.org/index.php/english/forum/31-cad-cam/27145-qcad-cam
Edit: I did manage to get dxf2gcode to work by changing the permissions on dxf2gcode.py to execute but the resulting G code was not what I expected... QCad CAM is more predicable but you do have to create your own offsets.
JT
Last edit: 06 Nov 2013 21:35 by BigJohnT.
Time to create page: 0.072 seconds
