7i33 pwmgen.value question
05 Feb 2012 21:15 #17444
by justin
7i33 pwmgen.value question was created by justin
Hello,
I have a 5i20 and 7i33 and I am interfacing with a vfd which wants a 0-10vdc signal. So originally I had the pwmgen value +/-10vdc but made it positive 10v regardless of spindle direction by using abs. In hal meter it is showing appropriate positive values for the pwgen.value. However when I a measure between the DRV2 and Ground on my 7i33 I get the exact value only negative.
When I am not using the abs component and I input an m4 hal meter shows a negative value on pwmgen.2.value but it outputs a positive dc voltage to my vfd and it works fine!
I am sure i am missing something simple here....
Here a section on my .hal file
#spindle scales
addf scale.0 servo-thread
addf scale.1 servo-thread
setp scale.0.gain 0.0001666
setp scale.1.gain 60
loadrt abs count=4
addf abs.0 servo-thread
addf abs.1 servo-thread
addf abs.2 servo-thread
addf abs.3 servo-thread
#spindle speed out limits
loadrt limit1 count=1
addf limit1.0 servo-thread
setp limit1.0.min -6000
setp limit1.0.max 6000
#set scale and pwm
setp hm2_5i20.0.encoder.02.scale -4096
setp hm2_[HOSTMOT2](BOARD).0.pwmgen.02.output-type 1
net spindle-speed-limit motion.spindle-speed-out => limit1.0.in
net spindle-speed-limit-out limit1.0.out => scale.0.in
net spindle-speed-DAC scale.0.out
net spindle-speed-DAC-abs => hm2_5i20.0.pwmgen.02.value
#net spindle-speed-DAC => hm2_5i20.0.pwmgen.02.value
net spindle-rpm => abs.1.in
net spindle-speed-abs <= abs.1.out
net spindle-speed-DAC => abs.3.in
net spindle-speed-DAC-abs => abs.3.out
net spindle-enable-req motion.spindle-on => and2.1.in0
net spindle-brake-sensor hm2_5i20.0.gpio.051.in_not => and2.1.in1
net spindle-enable and2.1.out => hm2_5i20.0.pwmgen.02.enable
#spindle scales
loadrt abs count=4
#set scale and pwm
06 Feb 2012 00:28 #17448
Replied by cmorley on topic Re:7i33 pwmgen.value question
change you pwmgen scale from negative to positive.
setp hm2_5i20.0.encoder.02.scale 4096
06 Feb 2012 05:17 #17450
by justin
Replied by justin on topic Re:7i33 pwmgen.value question
Thanks for the reply. I just tried changing it and it does not seem to reverse the actual dc voltage from the 7i33. I imagine it would be a bad idea to simply swap the drv. and ground wires to the VFD. Would this cause grounding problems?
06 Feb 2012 06:03 #17451
Replied by PCW on topic Re:7i33 pwmgen.value question
If the VFD signal is ground, yes it will cause troubles and possibly damage the 7I33
I think cmorely meant for you to change the PWM scale, not the encoder scale:
setp hm2_5i20.0.pwmgen.02.scale -oldscale
06 Feb 2012 07:22 #17452
by justin
Thanks, that makes a lot of sense. I will try that in the morning...
Justin
Justin
06 Feb 2012 20:03 #17472
Sorry yes thats what i meant.
08 Feb 2012 02:18 #17499
by justin
Solved!.... first using Abs to make the pwmgen.value positive for both m3 and m4 and then using a pwmgen.scale of -1 worked great. Thanks for the help as always.
Justin
Justin
