Warning after upgrade to Ver 2.7.0
- joekline9
- Thank you received: 14
02 Oct 2015 23:13 - 06 Oct 2015 05:55 #63374
by joekline9
Warning after upgrade to Ver 2.7.0 was created by joekline9
After upgrading to Linuxcnc 2.7.0:
using 5i25/7i77
I had to delete line in .hal for pet watchdog.
addf hm2_[HOSTMOT2](BOARD).0.pet_watchdog servo-thread
OK
Now it runs but I get the warnings below...
hm2/hm2_5i25.0: Warning: sserial remote device
7i77 channel 0 has firmware that should be updated
7i77 channel 1 has firmware that should be updated
anyone seen this?
using 5i25/7i77
OK
anyone seen this?
Last edit: 06 Oct 2015 05:55 by BigJohnT. Reason: no such version as 7.0
- Thank you received: 5291
02 Oct 2015 23:57 #63379
Replied by PCW on topic Warning after upgrade to Ver 7.0
This means you have 2-3 year old firmware in the 7I77 that has a bug
to fix, fetch
www.mesanet.com/software/parallel/sserial.zip
unzip the zipfile and cd to utils/linuxcnc and read the README file for instructions
to fix, fetch
The following user(s) said Thank You: joekline9
- joekline9
04 Oct 2015 04:00 - 04 Oct 2015 04:10 #63411
by joekline9
Replied by joekline9 on topic Warning after upgrade to Ver 7.0
Sorry to be a pain but I am getting errors when running
sudo sh update7i77
I extracted the zip file in Downloads. Does it have to be elsewhere?
See attached file
sudo sh update7i77
See attached file
Last edit: 04 Oct 2015 04:10 by joekline9. Reason: attach file
04 Oct 2015 04:31 - 04 Oct 2015 05:32 #63414
where does the README file say to run
sudo sh update7i77
I have just updated the README with a 7I77 example so it should be a bit more clear
You first open a terminal
then unzip the sserial.zip file (in your home directory or yourhome/Downloads or wherever)
then cd to utils/linuxcnc
read the README file ( in utils/linuxcnc ) and execute the scripts from that directory
sudo sh update7i77
Last edit: 04 Oct 2015 05:32 by PCW.
- joekline9
05 Oct 2015 04:59 #63436
by joekline9
Thanks PCW,
All works now. Firmware update for 7i77 worked as instructed. I just got a little confused before.
I love the new Trajectory planner in ver 7.0.
Thanks to all of you who help develope and support linuxcnc.
Time to create page: 0.062 seconds
