  • PCW
  • PCW's Avatar
14 Oct 2026 16:22
Replied by PCW on topic stepper motor does not move
You have:
FF1 = 0
in your ini file
This should always be 1
14 Oct 2026 14:58
Replied by tommylight on topic stepper motor does not move
LinuxCNC is very good at pointing out failures, so if you are not getting latency warnings while using it, it is not a latency issue.
When i replied about the low current, i was going to add that to much current can also do that, but it has to be way over the rated motor current to cause such issues.
In general,
-if the motor gets warm in 3 minutes, or hot in 5 minutes of being on = way to much current
-if it gets hot in 15-30 minutes = all should be good
-warm is if you can keep your palm on the motor
-hot is when you can keep your finger on it, but not the palm
-to hot is if you skin remains on the motor = the motor is cooked
keep in mind that current ratings on cheap drives are "peak", while on good expensive drives it is "RMS", but lately cheap drives have both ratings written on them, so use the "peak" values while testing, then decide if you need to add more current if the motor skips.
Always use lower current if not sure.
  • tuxcnc
  • tuxcnc
14 Oct 2026 14:24
Replied by tuxcnc on topic stepper motor does not move
The stepper motor withstands temperatures of 120 degrees Celsius.
This is, of course, the maximum parameter and during normal operation it should be cooler.
On the other hand, if the motor is cold, it means that the current is too low, resulting in less shaft torque.
Without a thermometer, this can be assessed by stating that the engine should be hot, but should be able to be touched by hand.
  • geebee
  • geebee
14 Oct 2026 12:58
Replied by geebee on topic stepper motor does not move
Sörry for eventually annoying anyone. Some reading I certainly did, it is just a lot of stuff. I have used several motors both of the same and different types and two different drivers. I can limit current at the tb6600 and certainly did. The cs-d508 does not provide any switch to do so. Its datasheet mentions overvoltage and overcurrent protection. Apparently the current nevertheless is too high, not too low. The motors heat up quickly when not moving. I lost a second one even though I have become more careful after the first one burned. I certainly do know how to wire a 2 phase stepper. Mistakes might happen, but I will not repeat them every time I reconnect the stuff. I have been working with steppers and arduino but not yet on a professional basis.
So at the moment, I suggest its more likely a latency issue. It is gonna take me a while to go through the stuff pcw has told me. After that, I will let you know what I did and what were the results.
Cheers
  • tuxcnc
  • tuxcnc
14 Oct 2026 12:30
The stepper motor pins can be checked without any tools.
Disconnect the motor from the controller.
Jump any two pins together.
Turn the motor shaft by hand.
If you feel a clear resistance, the pins belong to the same coil.
If the shaft rotates freely, the pins belong to other coils.
Shaft vibration instead of rotation is a typical symptom of confused wiring.
However, if the engine stands still and squeaks, it is a matter of settings, either the controller or the program.
14 Oct 2026 11:37
The motor vibrates when it is supposed to move but I cannot see or feel, respectively, any movement.
Causes for that might be wrong motor wiring to drive, or to low current set on the drive.
Check the motor wiring to drive first, there are strict rules on wiring winding A to output A, and winding B to output B.
Then read the manuals and set the drives to correct current for the motors you are using.
Was this with the step timing set to something extremely low like 2ns or similar? Why would you change stuff at random?
Friendly advice, stop messing with things and expecting them to work, do a bit of reading before actually wiring and running stuff.
14 Oct 2026 11:31
 Please note that according to the advice from tommylight I set the ip adress of the mesacard to 10.10.10.11 instead of 10.10.10.10.
It clearly states to set the PC network attached to Mesa to 10.10.10.11 or anything else except 10.10.10.10 as this is the actual Mesa card IP.
You have set it correctly as your ping results to 10.10.10.10 prove, so all is good.
  • PCW
  • PCW's Avatar
14 Oct 2026 10:31
The ping times show that the host is set to a 10.10.10.11 IP address and the 7I95T is set to 10.10.10.10
With and Intel MAC you should disable IRQ coalescing:
man hm2_eth
For testing, you can temporarily disable IRQ coalescing with this command:
sudo ethtool -C eno1 rx-usecs 0
( replace en01 with your Ethernet device name if different )
For testing general host latency,  when a base thread is not used (like with Mesa cards),
you should run the latency test with the base thread disabled:
latency-test 1ms
or
latency-histogram --nobase -sbinsize 500
Also you should go through all the standard latency reducing methods here including the isolcpus grub setting:
linuxcnc.org/docs/html/install/latency-test.html
Just to get things going you should make sure the step time is 5000
and worst case you may need to increase the servo tread period to say 2 ms
(2000000 ns)
  • geebee
  • geebee
14 Oct 2026 09:56
 Please note that according to the advice from tommylight I set the ip adress of the mesacard to 10.10.10.11 instead of 10.10.10.10.In opposition to the ones above the ping results are now with mesacard on the Intel adapter, not the Realtek.
--- 10.10.10.11 ping statistics ---
60000 packets transmitted, 60000 received, 0% packet loss, time 59999ms
rtt min/avg/max/mdev = 0.004/0.005/0.103/0.001 ms
geebee@debian:~$ sudo chrt 99 ping -i .001 -q -c 60000 10.10.10.10
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
--- 10.10.10.10 ping statistics ---
rtt min/avg/max/mdev = 0.139/0.253/0.368/0.010 ms
geebee@debian:~$
  • PCW
  • PCW's Avatar
14 Oct 2026 08:37 - 14 Oct 2026 08:39
You are pinging the host PC, not the 7I95T
try:
( It will run for 1 minute then print timing statistics )
  • geebee
  • geebee
14 Oct 2026 07:32
I changed the network adapters: Mesacard is now Intel 82579V, internet Realtek RTL8111/8168/8411
ping times now are 0.019 - 0.022 ms compared to approx. 0.03 ms before (see attachment).
No change in behaviour. The motor vibrates when it is supposed to move but I cannot see or feel, respectively, any movement.
  • anfänger
  • anfänger's Avatar
14 Oct 2026 06:42
Replied by anfänger on topic Hermle auswahl Mesa Karten
Category: Deutsch
sind die Glaasmesstäbe noch "original" an der Maschine? Dann sind dass ggf analoge, es gibt konverter (die habe ich auch) hat bei mir aber nie ganz sauber funktioniert. Habe die dann gegen neue getauscht. Weiß aber nicht was das nen Haus weg hatte die Konverter oder die Stäbe.
Ich würde die Endschalter der achsen nicht zusammenfassen. Macht die Fehlersuche leichter.
Ich persönlich würde auch mehr Ausgänge machen, wie reglerfreigabe und ggf Schütze für die Stromversorhung der Hochspannung an den Treibern.
Bzw das ist ja eine die schon ne steuerung hatte, da würde ich mir die Liste der IOS aus den Manuals / Stromlaufplänen ziehen.
  • geebee
  • geebee
14 Oct 2026 05:10
I was not really aware of latency issues since according to my understanding the signals are provided by the mesa card. Whether mine does so correctly I cannot tell ( and dont know how to test ) so far. In the attachments the information you asked for.The latency test was done while in the internet but no more additional load for the computer. Neither a latency test done in the past nor hardware recommendations from the web gave me any hint this could in my case be a problem. Next, I will do some research about how to adjust the bios in order to improve things.
Cheers
geebee
  • Hermle_Gerald
  • Hermle_Gerald
14 Oct 2026 04:27 - 14 Oct 2026 04:31
Replied by Hermle_Gerald on topic Hermle auswahl Mesa Karten
Category: Deutsch
Ich habs jetzt mal etwas genauer durchgedacht:
Lenovo Thinkcentre als Pc
Portables18,5 Zoll Touch Display (wird gerade getestet)
Sew Movitrac MCLTEB0022-5A3-4-00 für die Hauptspindel, Ansteuerung 0-10V/rechts/links
3x Ac Servo Driver 230V Model: JMC - JAND 10002-20B
3x Heidenhain Glasmaßstab
3x Ausgang für die Achsklemmung x/y/z
1x Ausgang Werkzeugspannen sk40
1x Ausgang Kühlmittelpumpe
2x Ausgang für Getriebeschaltung Motor Rechts/Links
7x Ausgänge gesamt + einige Reserve. Die aktiven Taster am Bedienpult sollten wenn möglich Leuchten.
3x Eingang Endschalter
1x oder 3x Eingang Hardware Endschalter. Ich denke man könnte alle drei Achsen zusammenfassen.
5x Eingang Programm: Start, Pause, Stop, Vorschub Stop, Spindel Stop
5x Eingang Achse verfahren: +/-, Eilgang, x, y, z
2x Eingang Getriebeschaltung, Getriebestellung mit zwei Taster (Zweigang Getriebe)
1x Steuerspannung Ein/Aus
1x Not Aus
18x Eingänge gesamt + Reserve
3x Poti Eingang: Eilgang, Vorschub, Spindel
Ich habe keine Ahnung wie man am besten die Servos ansteuern sollte? Im Endeffekt muss die Position von den Glasmaßstäben kommen. Ich hoffe Ihr könnt mir dabei helfen.
  • romanetz
  • romanetz
14 Oct 2026 04:23
ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Category: Driver Boards
(venv) engin@engin:~/litex-work/liteeth/bench/ESC$ ethercat slaves -v -p 0
=== Master 0, Slave 0 ===
Device: Main
State: PREOP
Flag: E
Identity:
 Vendor Id:       0xdeadbabe
 Product code:    0x00c0ffee
 Revision number: 0x00000001
 Serial number:   0x00000000
DL information:
 FMMU bit operation: no
 Distributed clocks: no
Port  Type  Link  Loop    Signal  NextSlave
  0  MII   up    open    yes             -
  1  MII   down  closed  no              -
  2  N/A   down  closed  no              -
  3  N/A   down  closed  no              -
Mailboxes:
 Bootstrap RX: 0x0000/0, TX: 0x0000/0
 Standard  RX: 0x1000/128, TX: 0x1080/128
 Supported protocols: CoE
General:
 Group: Colorlight5A75E
 Image name:
 Order number:
 Device name: Colorlight 5A-75E EtherCAT Device
 CoE details:
   Enable SDO: yes
   Enable SDO Info: no
   Enable PDO Assign: no
   Enable PDO Configuration: no
   Enable Upload at startup: no
   Enable SDO complete access: no
 Flags:
   Enable SafeOp: no
   Enable notLRW: no
 Current consumption: 0 mA
Displaying 406 - 420 out of 11392 results.
Time to create page: 0.209 seconds
