  • N3pu
  • N3pu
06 Oct 2025 18:02
Probescreen versa v1 Problem with XYZ Auto-Zero Gmoccapy LinuxCNC 2.9.1
Thanks for confirming it´s a bit strange :)
I´ve now tried again the newer probescreen v.2.9 where I didn´t connect the toolchange pins (this was the initial reason for using the older screen v1). It seems to gerneral work, too. But with a strange behavior like in v1.
Probing in Z seems to work fine. When I touch Probing from X-, Y- the machine starts moving in X+ direction until it prompts "finished without probing..". It should move in X- first, Z down, and then X+ for touching.. Crazy behavior.
In my case it starts directly moving X+ without moving Z..
I allready checkt the macro files. everything seems to be okay. any idea how to debug it?
  • N3pu
  • N3pu
06 Oct 2025 17:52
Replied by N3pu on topic door signal implementation
i have something similar implemented in my machine.
I have door closed signal, door locking signal (combined door sensor and locker). When TC is requested door is free of lock. When door is opened in manual mode when spindel is running. spindel stops.
Attached you´ll find my hall (linux cnc 2.9.1). Search for door in the hal file (should be at the end). Hope you can recycle something..
  • juergen-home
  • juergen-home
06 Oct 2025 17:51
toggle2nist hangs when pressing an other button at the same time
Category: HAL
Many thanks.
I compiled in your magic code in. With a puls-lenght of 50 my problems seem to be gone. This should become the standard toggle2nist.
Many thanks!
  • MatthiasCNC
  • MatthiasCNC
06 Oct 2025 17:47 - 06 Oct 2025 17:47
Replied by MatthiasCNC on topic CiA 402 in 1.15.0
CiA 402 in 1.15.0
Category: EtherCAT
Thanks.
Yes, I switched to the generic driver. After studying the nearly 1000 pages of documentation, I didn't see any advantages :-).
I can configure the converter very well directly.
The tip helped me. I had to remove “name=‘D1’” and add “configPdos=”true".
You have to pay attention to upper and lower case here.
<slave idx="0" type="generic" vid="0x0000001d" pid="0x007b1a95" configPdos="true">
Then there were a few minor things in the ini and hal files. Now my bus is running.
Now I just have to take care of the units.
Displaying 13141 - 13144 out of 13144 results.
Time to create page: 2.915 seconds
