  • Hakan
  • Hakan
10 Feb 2026 08:09
Technical questions about CIA402 and homecomp.comp on A6
Category: EtherCAT
From what it looks like, the only way out from homing is that is finishes.
This could probably be expanded to include error states and whatever can occur.
  • Hakan
  • Hakan
10 Feb 2026 08:01 - 10 Feb 2026 09:43
Replied by Hakan on topic How good is Ethercat motion control?
Category: EtherCAT
That's actually not often the problem. It isn't a very big problem.
For rigid tapping, threading and other synchronized moves repeatability is the key
Always the same starting position, follow the previous tool path
and that is the case even with a slight delay in the position from an axis.
To put in perspective, say a feed of 600 mm/min, gives a following error of 20 micrometer from 2 1 ms servo cycles delay.
Homing with switches should also be okay as long as homing is always done the same.
And, there is usually a slow feed state at say 30 mm/min => 1 micrometer off due to feedback delay.
Repeatability comes down to switch repeatability.
Homing on index is not affected.
The only real situation I can think of right now is with probing.
But again, probing speed of say 30 mm/min gives 1 micrometer off due to feedback delay.
  • meister
  • meister
10 Feb 2026 07:03
Replied by meister on topic How good is Ethercat motion control?
Category: EtherCAT
The only problem is when you want to synchronize with external movements (like tapping).
  • Gogonfa
  • Gogonfa
10 Feb 2026 06:33 - 10 Feb 2026 06:45
Replied by Gogonfa on topic How good is Ethercat motion control?
Category: EtherCAT
You don’t have a real following error! LCNC is only behind if it measures the following error! It compares an old position which comes time delayed due to the Ethercat cycle!
I modified the DeAsda Hal driver so that I can read out the real following error of my DELTA Servo driver. At 20m/min, the error is less than 20micron (LCNC is showing something around 1.8mm) At normal speeds e.g. 6m/min, the following error is below 1micron (my servos do have 24-bit encoders)
That means, you can simply forget the LCNC following error….just make it large so that it does not stop your system! Use instead the following error limits in your drive or use the drive following error in LCNC to make your own Stop or Warning routine in LCNC, but don’t forget….the servos must be absolutely perfect tuned in the drive and do not use any p I d parameters in LCNC for that drive!!!
  • markbaenen
  • markbaenen
10 Feb 2026 04:34
Replied by markbaenen on topic Configuration Problems 7i92 PnCConf
Category: PnCConf Wizard
When I have time I will write up a "5aBOB for Dummies". My big router will use a 7c81 x 5aBOB.
  • NWE
  • NWE's Avatar
10 Feb 2026 04:14
Replied by NWE on topic Ethercat panel configuration
Category: EtherCAT
For what it's worth, searching aliexpress for panel21190e finds some similar items.
I notice one of the pictures shown at  www.aliexpress.us/item/3256808758453292.html  appears identical to Soccer Kid's panel.
  • harindugamlath
  • harindugamlath
10 Feb 2026 03:54
Replied by harindugamlath on topic Ethercat panel configuration
Category: EtherCAT
Can you kindly share more info about this ethercat panel?
Where did you get it and model? And a few more photos?
  • Bansardo
  • Bansardo
10 Feb 2026 03:33
Replied by Bansardo on topic Can the OPI5 be Configured to Run LCNC?
Sorry for the late reply, that image should also work for de OPI5 plus if you only edit in "armbianEnv.txt" the line:
fdtfile=rockchip/rk3588s-orangepi-5.dtb
to:
fdtfile=rockchip/rk3588-orangepi-5-plus.dtb
How can I do this? It is won't startup. I must write iut to SD card and change this parameter and than with dd transfer all to emmc?
  • harindugamlath
  • harindugamlath
10 Feb 2026 03:27
Replied by harindugamlath on topic How good is Ethercat motion control?
Category: EtherCAT
Huge thanks to everyone for the great discussion. It's crystal clear now. We're sort of running a open loop like system with LCNC and letting the drives handle the motion.
But the added benefit getting a real world following error is great to monitor and possibly to adjust the feed to keep everything tight. Which reminds me of Fanuc AICC.
Professional controllers like Fanuc, Mitsubishi etc. are using fiber optic communication to the drive and has some sort of tracking error control options such as AICC II or smoothing options, I'm guessing they're doing the same thing?
10 Feb 2026 02:51
Replied by tommylight on topic Configuration Problems 7i92 PnCConf
IO Connections for P2
Pin#  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir
 1      0   IOPort       PWM              0        PWM             (Out)
14      1   IOPort       None
 2      2   IOPort       StepGen          0        Step/Table1     (Out)
15      3   IOPort       None
 3      4   IOPort       StepGen          0        Dir/Table2      (Out)
16      5   IOPort       StepGen          8        Step/Table1     (Out)
 4      6   IOPort       StepGen          1        Step/Table1     (Out)
17      7   IOPort       StepGen          8        Dir/Table2      (Out)
 5      8   IOPort       StepGen          1        Dir/Table2      (Out)
 6      9   IOPort       StepGen          2        Step/Table1     (Out)
 7     10   IOPort       StepGen          2        Dir/Table2      (Out)
 8     11   IOPort       StepGen          3        Step/Table1     (Out)
 9     12   IOPort       StepGen          3        Dir/Table2      (Out)
10     13   IOPort       None
11     14   IOPort       QCount           0        Quad-A          (In)
12     15   IOPort       QCount           0        Quad-B          (In)
13     16   IOPort       QCount           0        Quad-IDX        (In)
Where :
Pin# = is the equivalent parallel port pin number
I/O = is the pin number on the 26 pin header, see the manual for the board you have
Sec. func = is easy as it is written what function is active for that pin
Chan = the channel for the above function
Pin func = easy, just mind the step/dir and ignore the table thing
In general, you need the manual for the pinout and the mesaflash --readhmid report to figure pins out.
These are not parallel ports (even those have different modes that vary inputs and outputs, like "out","in", or "X"), these are Field Programmable Grid Arrays, meaning they can be programmed to pretty much everything within reason, so the pins will change, functions will change, etc, etc.
In short, there is no easy way to put all the thousands of pin options/functions into a wizard, especially as we keep asking from Mesa to make new firmware for whatever we happen to be working on at any given time, and they always, always make whatever we ask, no matter how strange it might seem.
So, thank you to Mesa and PCW for the best support on planet Earth.
  • Nathan40
  • Nathan40
10 Feb 2026 02:49 - 10 Feb 2026 03:11
Replied by Nathan40 on topic Using 7c81 with 5v encoder on bob3 config
Category: Driver Boards
Hi
Wiring looks ok to me. Please guide for the below points if they can help
a. Should I decrease the input voltage to 3 V. Will that help?
b. Should I decrease the output voltage of the encoder using a divider?
c. Perhaps changing the below values?
setp    hm2_7c81.0.encoder.00.counter-mode 1
setp    hm2_7c81.0.encoder.00.filter 0
setp    hm2_7c81.0.encoder.00.index-invert 0
setp    hm2_7c81.0.encoder.00.index-mask 0
setp    hm2_7c81.0.encoder.00.index-mask-invert 0
  • markbaenen
  • markbaenen
10 Feb 2026 01:27
So 10 - 13 match with 30 - 33, 17 -> 24, Estop -> 20.
Is there a guide for this? I.ve looked HARD and found nothing. The PnCconf docs skip right over this.
  • PCW
  • PCW's Avatar
10 Feb 2026 00:38
Replied by PCW on topic Hurco BMC 30 AP
Hurco BMC 30 AP
Category: CNC Machines
# ---PWM Generator signals/setup---
##setp hm2_7i97.0.pwmgen.00.scale [JOINT_0]OUTPUT_SCALE
##setp hm2_7i97.0.pwmgen.00.output-type 1
##setp hm2_7i97.0.pwmgen.00.offset-mode true
If you want to delete the TEST sections, either don't delete
this part, or delete it and uncomment the commented out section
above (since they are duplicates)
##################TEST#############################
setp hm2_7i97.0.pwmgen.00.output-type 1 #PWM pin0
setp hm2_7i97.0.pwmgen.00.offset-mode 1 # offset mode so 50% = 0
10 Feb 2026 00:19
Replied by tommylight on topic Hurco BMC 30 AP
Hurco BMC 30 AP
Should also get rid of the TEST part completely, left side of pin names are just pin names (non existing ones that you created) so they will do nothing as they are.
So you will most probably need to uncoment all the listed stuff from PCW, for all joints/axis.
  • NWE
  • NWE's Avatar
09 Feb 2026 23:58
Category: EtherCAT
What we need is a way to "link" the two joints (example: X and X-slave)... Am I correct, currently we tell both to home and just expect them to go?
If one isn't ready, or simply fails to move, we would prevent both from moving.
What if CIA402 component had some pin, maybe an io pin to monitor, and any drive connected to it could set it, causing them all to halt?
net gantry-halt-interlock   <=> J1.cia402.halt
net gantry-halt-interlock   <=> J2.cia402.halt
If a drive is commanded to move, try clearing the pin just once. If a drive is faulted and sees this pin got cleared, set it again.
Or maybe a better way, (or additionally?) monitor both joint positions, if the difference exceeds some value, stop both?
Just throwing the idea out there. Maybe I'm just making noise.
Displaying 2491 - 2505 out of 17360 results.
Time to create page: 0.262 seconds
