  • cakeslob
  • cakeslob
30 Jul 2024 20:32
I've flashed remora-rt1052-nvem-0.2.1.bin, is that the right bin?
probably not, but I dont think you are working out of the correct repo
github.com/scottalford75/Remora-RT1052-cpp/tree/main/Firmware
  • klopp
  • klopp
30 Jul 2024 19:49
Replied by klopp on topic Weiler 160 CNC Retrofit
Category: Show Your Stuff
Aah of course, H is the once-per-rev signal. Somehow didn't occur to me, but now it makes sense, thank you!
They are connected directly to the ballscrews, the spindle encoder is connected via belt. They use "Heldt & Rossi SM 807 DC" servo drives for X and Z and a "Baumüller BKF 12/70/400" for the spindle. Controller is a "Sinumerik 3T".
  • MarkoPolo
  • MarkoPolo
30 Jul 2024 19:49
Replied by MarkoPolo on topic Error in tool_offsetview.py
Category: Qtvcp
For now, m5 solves the problem in my tool measurement procedure. I do not use the built-in qtvcp procedures. Let someone smarter figure out how to solve the problem, I probably can't help.
Returning to the topic of the axis buttons function. Could you add the "go to zero" function?.
I only added the titles to the axis_tool_button.py file to the screenshot. I do not have the functions working yet.
  • spumco
  • spumco
30 Jul 2024 19:34
Replied by spumco on topic Weiler 160 CNC Retrofit
They look like 'normal' differential encoder outputs.  A/A-, B/B-, and H/H-... with H being the once-per-rev index signal.
Should be a standard Mesa connection.
Are those encoders connected directly to the ballscrews, or to the motors?  What's driving the motors?
  • klopp
  • klopp
30 Jul 2024 19:14
Weiler 160 CNC Retrofit was created by klopp
After years of using a very old (1930) and worn out lathe, I decided to get myself something new.
Found a Weiler 160 CNC in very good condition (400 spindle hours) that has been used lightly in a school. The buffer battery is dead and the screen does not turn on anymore, so a perfect project for a retrofit.
The documentation is one of the best I've ever seen, everything from bearing preloading up to motor change of the toolchanger is described. Tons of drawings from every part. The whole machine just screams german quality.
Only thing I'm not really sure about is the measuring system. It uses incremental encoders with 6 signal pins instead of glass scales. Does anyone know how I connect them to the mesa cards? Can I use the normal encoder inputs for that or do I need something else?
  • PCW
  • PCW's Avatar
30 Jul 2024 19:13
Quadrature decoding to produce pulse + direction
Category: HAL
Yes, basically LinuxCNCs motion component already does this with the MPG count.
30 Jul 2024 18:52
I have full version of debian 12.6 installed on my machine
Category: Installing LinuxCNC
sudo apt update
sudo apt upgrade
sudo apt install linuxcnc-uspace
30 Jul 2024 18:51
Replied by tommylight on topic Quadrature decoding to produce pulse + direction
Category: HAL
Hmmmm why?
LinuxCNC can use any encoder as MPG, so no need to convert anything, even on parallel port it works.
  • Lpkkk
  • Lpkkk
30 Jul 2024 18:35
  • frogandspanner
  • frogandspanner
30 Jul 2024 17:44
Quadrature decoding to produce pulse + direction was created by frogandspanner
Category: HAL
I am building an MPG control for a Chinese 920 lathe I am converting to CNC. I want the controls to have the same intuitive feel as the original manual lathe, with the option of overriding to use full CNC, so will be fitting an MPG where the standard controls would be. I have the prototype setup working, using _encoder_ to decode the quadrature encoding (it is strange the the decoder component is called "encoder"). This produces a count, but I'd also like quadrature decoded to pulse + direction for further processing.
Is there any way of doing that with standard HAL components?
  • PhilipME
  • PhilipME's Avatar
30 Jul 2024 17:42
When I loaded latest debian, I thought linuxcnc will be included.
Can any one point me to the procedure where I can install linuxcnc to my existing debian 12.6
I already constructed a DIY machine running on linuxcnc using another pc, but I like the full version of debian 12.6.
Many thanks
Philip
  • my1987toyota
  • my1987toyota's Avatar
30 Jul 2024 17:17
Replied by my1987toyota on topic Was the SPAM topic a test
yeah I figured I would have some fun with it. LOL
30 Jul 2024 17:10
Replied by tommylight on topic Was the SPAM topic a test
Already dealt with, thank you for "never gona give you up" and "spam with spam on top of spam" ! :)
  • AndyDM01
  • AndyDM01
30 Jul 2024 16:44
Replied by AndyDM01 on topic Ethercat build from source - full instructions
Category: EtherCAT
I have a question about the realtime.mk file...
how do I get it perfect? everything went ok untill i can't make this file, some seperator missing
thx
  • my1987toyota
30 Jul 2024 16:36 - 30 Jul 2024 17:07
it seems they're multiplying.
and now they're gone. Thank you to whoever takes care of that.
Displaying 24256 - 24270 out of 25074 results.
Time to create page: 0.899 seconds
