  • rodw
  • rodw's Avatar
09 Jul 2024 23:27
Replied by rodw on topic EtherCat - CATIO module Help
Category: EtherCAT
I have the same io card. I have configured digital input and output, analog input and output, counter input and pwm output. Now the only thing left is the encoder. The encoder of this io card outputs the count value without abz phase. How to convert the count value to abz phase?
That does not appear possible. Just scale the count back into counts per mm
You could toggle bits 8 & 9 of 0x2040 to zero the count
The manual was a nice find.
  • Dorro1971
  • Dorro1971
09 Jul 2024 23:04
Replied by Dorro1971 on topic mesaflash_for_tormach
Category: PathPilot
Well, after pulling what's left of my hair out I have managed to get Pathpilot to play nicely with a Mesa 7I80HDT...I flashed the board with a custom bitfile, edited pathpilotmanager.py in the python directory...(removed the mesa verify bitfile and forced pathpilot to recognise the board as a 7i80) My thanks to Mesa electronics for keeping the registers and datagrams the same between the xylinx and efinity fpgas.
I managed to get my 7I96S to almost work but of course the transformer drive for the isolated output would not work...I thought about modifying the output drive to normal ssr's but didn't see the point.
Now I have 72 pins at my disposal..
If there is any interest I will explain in more detail, I suspect most ethernet boards would work depending on the types of modules required.
Once again, my thanks to Mesa electronics for a great product range.
Dorro.
  • Pro_El
  • Pro_El's Avatar
09 Jul 2024 21:04
Replied by Pro_El on topic EtherCat - CATIO module Help
Category: EtherCAT
I have the same card, can you share your xml for testing??
  • ississ
  • ississ's Avatar
09 Jul 2024 19:53
Replied by ississ on topic Aktuelle hardware mit PCI
Category: Deutsch
Testen Sie Ihr Setup und verwenden Sie es, wenn es funktioniert.
Wenn nicht, gibt es noch viele weitere Motherboards mit PCIe und Adapter.
PCIe-Riser und Adapter mit 5i25, eingebaut in ein altes Topfield-Gehäuse. Funktioniert gut.
(translated by google)
Hallo und guten tag,
Ich habe nun den adapter bekommen auch die PCI-x peitsche und das Molex kabel.
Der rechner läuft die Adapterkarte wird erkannt der rechner startet mit linuxcnc
so weit so gut doch sobald ich die 5i25 in den pci adapter stecke schaltet sich der rechner nicht mal mehr ein
die 5i25 hab ich auf einem alten Gigabyte GA-B75M-D3H getestet da läuft sie anscheinend spricht das system falsche buss register an
haben sie eine möglichkeit zur lösung des problems?
danke und schöne grüße aus österreich:)
Sie haben es irgendwie geschafft, die Mesa-Karte falsch herum zu installieren.
Beide Karten sollten Komponenten auf derselben Seite haben. Die korrekte Position finden Sie in meinem Setup.
Und hoffe, dass die Karten nicht wegen der falschen Verbindung kaputt gehen...
  • thadhughes
  • thadhughes
09 Jul 2024 19:36
Replied by thadhughes on topic Replacing SWI TRAK CNC 2 Controller
Category: Milling Machines
Zenduin,
I'm working on this same thing - happy to see you've somewhat trod before me. Any updates on this project?
I am looking at using a 6i24 + 7i52s ... and as I'm scoping the signal wires I'm finding what you're seeing, but the peak-peak voltage on the PWM signals is about 3.3V. Are you hooking the 7i52s directly to these lines, or are you stepping down the voltage at all with any sort of level shifter?
  • PCW
  • PCW's Avatar
09 Jul 2024 19:29
watchdog and network connection problems
Category: Installing LinuxCNC
A red light on 7I96S at power up likely means you have a marginal
5V power issue or corrupted flash memory.
  • jg00163206
  • jg00163206's Avatar
09 Jul 2024 19:27
Replied by jg00163206 on topic watchdog and network connection problems
heres what i get when i ping the 7i96s; ping 10.10.10.10
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
From 10.10.10.1 icmp_seq=1 Destination Host Unreachable
From 10.10.10.1 icmp_seq=2 Destination Host Unreachable
From 10.10.10.1 icmp_seq=3 Destination Host Unreachable
From 10.10.10.1 icmp_seq=4 Destination Host Unreachable
From 10.10.10.1 icmp_seq=5 Destination Host Unreachable
From 10.10.10.1 icmp_seq=6 Destination Host Unreachable
From 10.10.10.1 icmp_seq=7 Destination Host Unreachable
From 10.10.10.1 icmp_seq=8 Destination Host Unreachable
From 10.10.10.1 icmp_seq=9 Destination Host Unreachable
From 10.10.10.1 icmp_seq=10 Destination Host Unreachable
From 10.10.10.1 icmp_seq=11 Destination Host Unreachable
From 10.10.10.1 icmp_seq=12 Destination Host Unreachable
^C
--- 10.10.10.10 ping statistics ---
15 packets transmitted, 0 received, +12 errors, 100% packet loss, time 14380ms
pipe 4
and the red light is on on the mesa 7i96s.
  • jg00163206
09 Jul 2024 19:23
unable to run pncconf. it freezes and says its not responding and asks if i want to exit the program. and the red light on the board is on and i am unable to ping the 7i96s. host unreachable.
  • jg00163206
09 Jul 2024 18:56
okay, i just reinstalled Debian and setup the network interface and i am getting ping responses. and no red light. yet. i am going to go through the process of installing lcnc
  • jg00163206
09 Jul 2024 18:48
i even used a different Ethernet cable to make sure it wasn't the cable and no improvement. there are only lights on the rj45 connector on the mesa board after i reboot the board. and i can get a ping time from it for a couple seconds then it goes to host unreachable and it drops most of the packets. i haven't installed ANY wizards lately. or tried to flash the firmware. if i can't read the board, i don't think flashing will do much good. at what point do we start to question the hardware? is there a way to test the board to make sure it is operation properly?
  • Roguish
  • Roguish's Avatar
09 Jul 2024 18:25 - 09 Jul 2024 18:26
Spindle Inhibit while Probing..... was created by Roguish
Category: Qtvcp
Feature request, I think.  for QtDragon, and maybe QtDragon_hd
How about a spindle inhibit, while probing?
Maybe even with a probe installed?
Something like an optional input for the probe tool number on the probe page(s).
And a check box for spindle inhibit.....
sure would help.
Chris, what do you think?   shouldn't be too hard to implement...
09 Jul 2024 18:22
Replied by tommylight on topic watchdog and network connection problems
Check that both RJ45 connectors are plugged in correctly
In a terminal do
ping 10.10.10.10
if the link is OK the LED lights on the mesa board will count binary, i think
use a different LAN cable wired directly from PC to Mesa
Do not flash or attempt to flash the board with flaky connection, there is no need to ever flash the board if you do not specifically need something extra from it
Do not keep on trying wizards as there is no link
  • jg00163206
09 Jul 2024 17:08
i did install the dkms drivers. what i mean by watchdog; the red light on the mesa 7i96s will illuminate as soon as i turn the pc on. when i go into pncconf and try to test an axis, i get an error that the halcmd is not running and i should invoke halcmd start to resolve it but that has no effect. also, i am unable to flash new firmware to this board. i have installed mesact a number of times and the firmware section is greyed out every time. no matter what i do. and when i run mesaflash --addr 10.10.10.10 --device=ETHER --readhmid, it does nothing. no output. i have to hit ctl+c to get my terminal back. i am at a lose here. i don't know why installing a new ethernet board would give me these issues either. maybe someone knows of a different setup that wouldn't be so complicated to setup. heres the error report i amd getting when i run lcnc; Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.2
Machine configuration directory is '/home/mill/linuxcnc/configs/mill'
Machine configuration file is 'mill.ini'
INIFILE=/home/mill/linuxcnc/configs/mill/mill.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=qtvcp qtdragon
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./mill.hal
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:16:8a:7b
hm2_eth: ERROR: receiving packet: Resource temporarily unavailable
Running HAL shutdown script
Debug file information:
Note: Using POSIX realtime
rtapi_app: caught signal 11 - dumping core
./mill.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./mill.hal:9: /usr/bin/rtapi_app exited without becoming ready
./mill.hal:9: insmod for hm2_eth failed, returned -1
5535
Stopping realtime threads
Unloading hal components
Waited 3 seconds for master. giving up.
hm2_eth: not loaded
<commandline>:0: exit value: 255
<commandline>:0: rmmod failed, returned -1
hostmot2: not loaded
motmod: not loaded
trivkins: not loaded
homemod: not loaded
tpmod: not loaded
<commandline>:0: unloadrt failed
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Tue Jul 9 01:06:19 PM EDT 2024
UTC Date: Tue Jul 9 05:06:19 PM UTC 2024
this program: /usr/bin/linuxcnc_info
uptime: 13:06:19 up 52 min, 1 user, load average: 0.58, 1.10, 1.50
lsb_release -sa: Debian Debian GNU/Linux 12 (bookworm) 12 bookworm
linuxcnc: /usr/bin/linuxcnc
pwd: /home/mill/linuxcnc/configs/mill
USER: mill
LOGNAME: mill
HOME: /home/mill
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: lightdm-xsession
display size: 1360x768 pixels (360x203 millimeters)
PATH: /usr/bin:/home/mill/linuxcnc/configs/mill/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: 4axis
kernel-name -s: Linux
kernel-vers -v: #2 SMP PREEMPT_RT Mon May 1 17:18:20 AEST 2023
machine -m: x86_64
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-6.3.0-rt11-linuxcnc root=UUID=639fe864-e67c-4bdd-ba74-542c16092335 ro quiet nomodeset
model name: AMD Ryzen 5 2400G with Radeon Vega Graphics
cores: 4
cpu MHz: 2986.156
parport:
serial:
Versions:
gcc: gcc (Debian 12.2.0-14) 12.2.0
python: Python 3.11.2
git: not_in_PATH
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.9.2
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /usr/lib/linuxcnc/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
PYTHON: /usr/bin/python3
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii linux-headers-6.3.0-rt11-linuxcnc 6.3.0-2 amd64 Linux kernel headers for 6.3.0-rt11-linuxcnc on amd64
ii linux-image-6.3.0-rt11-linuxcnc 6.3.0-2 amd64 Linux kernel, version 6.3.0-rt11-linuxcnc
un linuxcnc <none> <none> (no description available)
un linuxcnc-doc <none> <none> (no description available)
ii linuxcnc-doc-en 1:2.9.2 all motion controller for CNC machines and robots (English documentation)
un linuxcnc-doc-es <none> <none> (no description available)
un linuxcnc-doc-fr <none> <none> (no description available)
un linuxcnc-sim <none> <none> (no description available)
ii linuxcnc-uspace 1:2.9.2 amd64 motion controller for CNC machines and robots
thanks for all the help. if anyone knows of a less complicated setup, i would open to any and all suggestions.
  • jhuth
  • jhuth
09 Jul 2024 16:50
PLEASE HELP: Sherline lathe/driver box + mesa: steppers only move 1 direction
Category: Turning
For what it's worth... I'm also just now setting up my Sherline 5800 NexGen Mill using the Sherline 4-axis Driver Box (PN 8760) via parallel port cable connection to my desktop computer with fresh install of LinuxCNC.
When I ran the Stepconf Wizard... only advanced each of my three axis steppers in single steps in ONE DIRECTION. Cannot figure out how to make step in other direction.
Do any Sherline Mill and Sherline Driver Box users here have advice on correct Stepconf settings for Sherline mills?
Displaying 25426 - 25440 out of 25535 results.
Time to create page: 0.714 seconds
