  • Hexagon
  • Hexagon
04 Dec 2025 13:52
Replied by Hexagon on topic EtherCAT servo as main spindle
Category: EtherCAT
I noticed that if I disable the machine the joint.0.motor-pos-cmd tracks the joint.0.motor-fb. So I set up a new hal file with only one cia402 and no cia402pv. Because you can't change the mode of the cia402 while LinuxCNC is running, I change between CSP and CSV by writing directly into the mode of the frequency drive via EtherCAT.
In CSP mode cia402.0.pos-fb -> joint.0.motor-pos-fb.
In CSV mode joint.0.motor-pos-cmd -> joint.0.motor-pos-fb.
So I have no following error in CSV mode, but I need to change the position before changing from CSV back to CSP or I can turn the machine off and back on again. I built a network with mux2, oneshot and flipflop to toggle the machine for a very short amount and to reset all my mode switching logic. This works surprising well and isn't noticable.
I know that this soultion is not good and only works for my usecase because I only have one servo and nothing gets interrupted by the power cycle.
The bigger problem is that my gcode file gets stopped aswell and I can't resume. Maybe there is a way by tracking the executed lines and then starting from there... But I'm not happy with the power cycle solution in the first place.
Is there any other situation where joint.0.motor-pos-cmd tracks joint.0.motor-fb?
  • Aciera
  • Aciera's Avatar
04 Dec 2025 13:20
Replied by Aciera on topic Gladevcp pin does not exsist
Category: GladeVCP
Looks like you got the pin name wrong. Try removing the 'gladevcp.' at the beginning.
  • nanowhat
  • nanowhat
04 Dec 2025 12:44
Ethercat drives not responding, mesa error finishing read
Category: EtherCAT
I figured it out. The manual doesn't explicitly mention SDOs but it does say whether an index can be assigned to a PDO and I ignored that information the first time around.
260B, 260C, and 260D cannot be assigned to a PDO.
Is there another way of getting this information into HAL, or do I need to write a custom component?
  • mmt
  • mmt
04 Dec 2025 12:40
Gladevcp pin does not exsist was created by mmt
Category: GladeVCP
Been quite a while since I've edited my linuxcnc v2.9.x Not sure what I am doing wrong here.
Help is appreciated
  • nanowhat
  • nanowhat
04 Dec 2025 12:30 - 04 Dec 2025 12:33
Category: EtherCAT
Output from "ethercat pdos" in attached file.
0x2605 works just fine: that's the DC link voltage and I can read that from all 3 drives.
0x260B does not.
The drive manual doesn't discuss SDOs, or whether some data index is a PDO or SDO. I would hope a temperature sensor would be continuously readable, which would require it to be a PDO.
  • Hakan
  • Hakan
04 Dec 2025 12:20
Category: EtherCAT
With pll-reset-count steady at to 2 it should be fine.
Try to locate temperature sensors in the pdo listing from "ethercat pdos".
I suspect you are addressing a sdo with 2605 and that won't work.
You'll find out from the ethercat pdos listing.
  • nanowhat
  • nanowhat
04 Dec 2025 12:20
Long initialization of Ethercat on servo drive SV660N
Category: EtherCAT
I recently did this and my exact command was:
"./configure --sysconfdir=/etc/ --disable-8139too --enable-userlib --enable-generic --disable-eoe"
  • nanowhat
  • nanowhat
04 Dec 2025 11:34
Category: EtherCAT
$lcecObject.pll-error-count is holding at 2. I haven't seen it increase yet.
I want to read some more data from the drives, and it won't work. See attached iX7NH.xml, line 23. I want to see the temperature values from the drive, but I can't read them. As shown, where pdoEntry idx="260B", the drive stays in PREOP (see dmesg output in dmesg260B.txt). If I change the index to "2606", the drive will go to OP (see dmesg output in dmesg2606.txt) and I can see the number through HAL (that I don't want). Registers 2606 and 260B are both 16 bit signed integers.
Any of 260B, 260C, or 260D (all temperature sensors in the servo system) have the same effect.
I can read the values manually with "ethercat upload -p0 -t int16 0x260B 0" and I get some number.
The drive manual says I can read up to 10 registers with one TxPDO: I have 6.
It also says that I am limited to 28 bytes in one TxPDO: I have 13.
How do I do this?
  • Hexagon
  • Hexagon
04 Dec 2025 11:11
Category: EtherCAT
The sync component only calculates the c-pos-sync.0.pos_cmd_out, but has no effect to the joint.0.motor-pos-cmd.
It takes joint.0.motor-pos-cmd as c-pos-sync.0.pos-cmd-in and joint.0.motor-pos-fb as c-pos-sync.0.pos-fb_in. The calculated delta is called offset. So in spindle mode cmd_out = fb_in, but cmd_in is fixed. That results in the following joint error.
FUNCTION(_) {
    if (!c_mode_active) {
        offset = pos_fb_in - pos_cmd_in;
        pos_cmd_out = pos_fb_in;
    } else {
        pos_cmd_out = pos_cmd_in + offset;
  • Hakan
  • Hakan
04 Dec 2025 10:38
Replied by Hakan on topic EtherCAT servo as main spindle
Category: EtherCAT
I thought ADm1N solved this with the c_pos_sync component?
  • Aciera
  • Aciera's Avatar
04 Dec 2025 10:08
Replied by Aciera on topic EtherCAT servo as main spindle
Category: EtherCAT
I'm not familiar with ethercat but the somewhat 'established' strategy when switching between spindle and rotary is to use a hal component to freeze the encoder position feedback when switching to spindle mode and reposition the spindle using M19 before switching back to rotary mode and reconnecting the encoder signal.
  • Hexagon
  • Hexagon
04 Dec 2025 09:34
Category: EtherCAT
The problem in spindle mode is, that the cia402 pos-fb is mapped to joint motor-pos-fb, but joint motor-pos-cmd is fixed. So joint f-error increases over time. Now I'm not sure how to solve this problem, cause I can't manipulate joint motor-pos-cmd. One way would be to freeze joint motor pos-fb, this way there is no f-error and track the movement to set an offset. But I can't figure out how to solve this, without writing to joint motor-pos-cmd.
The following error should also be a problem for aDm1N. But I assume it is less important, cause he only has 8000inc/rev, where I have 131072inc/rev, so the error adds up much slower. This would also explain FERROR = 1000000 in his ini.
  • PCW
  • PCW's Avatar
04 Dec 2025 09:24
Changes in configuration files generated in pncconfig for 7i76 to 7i78
Category: PnCConf Wizard
Whats actual hardware do you have?
It sounds like a 7C81 and one 7I78.
It that case is might be simpler to use something like a pncconf 5i25/G540 configuration
as a starting point as that would al least let you setup the PWM spindle in pncconf.
In general, if you have the correct firmware for the daughtercard, the pins don't matter
in the hal files, what is significant is the module number like stepgen 0,1,2,3, etc.
The exception is GPIO pins.
The 7I78 encoder pins will have names like hm2_7c81.0.encoder.00.position.
7I73 MPG encoders will have names like hm2_7c81.0.7i73.0.0.enc0.position
Note that you can list all pin and parameter names when LinuxCNC is running with:
halcmd show all hm2
  • Masiwood123
  • Masiwood123's Avatar
04 Dec 2025 09:13
Replied by Masiwood123 on topic Physical buttons to 7i96s+7i77
Category: HAL
there is a duplicate addif at the beginning of the file, so it appears as the first error, I commented on that, but it also appears another type of scalemax.1 in not found
  • MaHa
  • MaHa
04 Dec 2025 08:51
Replied by MaHa on topic python module
python module
Category: Flex GUI
Thanks. That worked.
Before, it was unsuccessful with linuxcnc status.
Now i tested, by press the pushbutton, i can read the file by lines
Displaying 10471 - 10485 out of 11228 results.
Time to create page: 0.282 seconds
