  • rodw
  • rodw's Avatar
01 Nov 2025 09:38
New ethercat / probe basic control for minimonster
Category: CNC Machines
immediate homing is covered here linuxcnc.org/docs/stable/html/config/ini...ml#_immediate_homing
But spending an hour wiring home switches will be well worth it!
I could not use a machine without home switches and yes I tried!
  • ihavenofish
  • ihavenofish
01 Nov 2025 09:29
Replied by ihavenofish on topic New ethercat / probe basic control for minimonster
Nothing seems to change when i home other than the joint error from the crash (i've blocked the axis). So maybe its not the drive homing after all.
still makes zero sense.
  • rodw
  • rodw's Avatar
01 Nov 2025 09:27
Sounds like you are set for internal homing. If you want to do Linuxcnc homing, use generic pin types which you can set in your XML and don't load a homemod. This still works well.
  • ihavenofish
  • ihavenofish
01 Nov 2025 09:19
ok, so
machine off:
controlword = 4
statusword = 2672
opmode = 8
machine on:
15
6711
8
press home all and instant crash and fault
saw something about forcing opmode 8, however this changes nothing. still full speed into the end stops.
another suggestion is to just inhibit motion, but that seems not right either. Need to find out WHY it is moving.
so if i home and crash, is there something in the controlword and statusword i should see? it happens in a few ms.
  • Hakan
  • Hakan
01 Nov 2025 08:49
halscope and record statusword and controlword.
  • ihavenofish
  • ihavenofish
01 Nov 2025 08:19
well we sorta already did that. there is no setting that doesnt either flicker the drives or slam the axis. like it does't respect search or latch vel at all.
that has to be a clue. something ELSE is making it home. maybe it IS doing internal drive homing?
  • Hakan
  • Hakan
01 Nov 2025 08:14
"Divide and conquer".
Comment out everything except one single axis and try until you find it.
  • ihavenofish
  • ihavenofish
01 Nov 2025 08:13
Yes it does have ethercat drives. And modbus nonsense as well.
bah!
haha. clearly i've botched something somewhere. i just cant see it.
  • ihavenofish
  • ihavenofish
01 Nov 2025 08:11
I don't think it is a good idea to combine homing on current position with HOME_OFFSET.
That means is set's zero exactly where it is and immediately after moves to HOME_OFFSET.
ive removed that now, now, no change. also that offset is + direction and it is slamming the thing full speed into the table.
  • Hakan
  • Hakan
01 Nov 2025 08:11
  • ihavenofish
  • ihavenofish
01 Nov 2025 08:10
does your lathe use ethercat drives?
this is what i had before with the pulse drives. everything was fine. And i could have sworn in my first ethercat program *before* all this modbus nonsense it was fine as well.
  • Hakan
  • Hakan
01 Nov 2025 08:10
  • Hakan
  • Hakan
01 Nov 2025 08:06
That's odd. Here is what I have in my lathe where it homes on current position.
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 1
MAX_VELOCITY = 20.0
MAX_ACCELERATION = 500.0
MAX_OUTPUT = 0.0
MIN_LIMIT = -106
MAX_LIMIT = 106
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_SEQUENCE = 0
  • ihavenofish
  • ihavenofish
01 Nov 2025 08:00 - 01 Nov 2025 08:01
If I set like the table in your posts, it still moves and slams the axis into the end stops.
If I set homing sequence to -1 it flickers the drive.
I do not want any internal homing on the drive. I want no motion whatsoever.
What "normally" works is not here.
  • Hakan
  • Hakan
01 Nov 2025 07:53
The docs at linuxcnc.org/docs/html/config/ini-homing.html says it
The cia402 component says
 For using the servo drives internal homing procedure configure your
joint homing to Home on Index Pulse only and connect the components
home Input to the index-enable Pin:
I don't see you have connected that pin.
To debug, use halscope and record controlword and statusword to and from the drive.
Displaying 11671 - 11685 out of 12858 results.
Time to create page: 0.570 seconds
