15 Nov 2026 09:25 - 15 Nov 2026 09:46
Replied by tommylight on topic Mesa Suppliers
Mesa Suppliers
Category: Driver Boards
Yes, the mesanet.com has an outdated deign as it was built in the 90's, but it is being maintained properly.
It is safe, just go to the shop
eusurplus is the web part of FastSeal co, and when you do bank transfer, it goes to a bank in Belgium i think.
I did not order personally, i had friends order from them and never had a single issue, at a guess i have spent over 5000 euro (lowballing it) there by now.
welektron is also fine, i have several thousand euros of Mesa cards ordered there, never a single issue.
AS for your web site security check, i would strongly recommend you completely wipe your PC as it is infected, badly.
Do NOT use it to make online payments.
Download any Linux ISO, preferably Mint Mate edition, write it to a USB stick, boot from it, order stuff, shut it down.
While at it, check those two websites you are dispensing misinformation about, they will check fine on Linux. Granted, you do not infect the browser on it, also.
Edit:
OK, web issue is fixed as i checked, see below, but it seems there was an incursion in recent history.
You can ignore the part above about your PC being infected, but you should really not ignore it, if using windows daily, use Linux for payments and security checks.
  • timwozni
  • timwozni
15 Nov 2026 08:34
Replied by timwozni on topic Mesa Suppliers
Mesa Suppliers
I decided to purchase a Mesa board to switch to LinuxCNC. However, despite the popularity of these boards, I encountered a significant trust issue when I reached the point of making a purchase. Let me explain the process I went through.
I considered buying a Mesa 7i96s board from Europe and set out to identify the official distributors in the region. First, I tried to locate the official Mesa website; my research led me to www.mesanet.com. The site appeared quite dated—as if it had been built in the 1990s—but I did manage to find a page listing their European distributors:
store.mesanet.com/international-dealersEuSurplus
FastSeal - Unipessoal Lda
Sitio Vale da Mo, 117x
Olhao 8700-175, Portugal
www.eusurplus.com
Welectron
76131 Karlsruhe
Germany
Contact: Marco Wunschmann
www.welectron.com
Email: This email address is being protected from spambots. You need JavaScript enabled to view it.
Tel: +49 721 909819-90
I noticed that the price at EuSurplus was quite reasonable. However, upon checking their contact page, I discovered that the company’s location was not correctly marked on Google Maps. When I manually searched for the Portuguese address they provided on their website, the result pointed to a company called "FastSeal Lda"—which, as it happens, is a well-known manufacturer of gaskets and seals. maps.app.goo.gl/5cyHmHzfgLQFWggi9
The street view for the FastSeal address looks like a house on a plot of land in a village... Anyway...
You do not have permissions to access this page.
Furthermore, the website did not accept payment methods like credit or debit cards. The fact that they only offered PayPal, Revolut, and bank transfers—and did not accept cards—only heightened my suspicions.
I then began to examine the mesanet.com website more closely. Upon inspecting the source code, I discovered that links to various illegal casino websites had been injected into the site's code.
Comparing the two websites, I realized they were strikingly similar—much like the same WooCommerce setup, just with different color themes. Naturally, my suspicions grew even further. It is possible that both the main website and the distributor’s website are mere copies created by the same individual.
I also tried to look up the location of Mesa’s U.S. office. It turned out to be a warehouse-like space in an area filled with motels and massage parlors, with only a tiny "Mesa" sign visible. I had expected to see a factory or an R&D office; I was quite taken aback.
I sent an email to the company, informing them about the malicious injections I had discovered on their website. Yes, many people here on the forum recommend it, but how can I trust it enough to make a purchase? Could you suggest a way for me to be sure it’s trustworthy?
I do not wish to cast suspicion on or accuse any company. This is simply the situation I experienced prior to making a purchase.
  • JT
  • JT's Avatar
15 Nov 2026 08:27
Replied by JT on topic Forum Upgrade #5
Forum Upgrade #5
Category: Forum
Yes, all posts will be in the new forum. None will be lost. I don't give estimates, sorry. I'll make the change as fast as possible but there is no control on DNS propagation at all. I've seen DNS propagation take seconds to hours...
JT
  • mwc
  • mwc
15 Nov 2026 08:17
Replied by mwc on topic Forum Upgrade #5
Forum Upgrade #5
Category: Forum
Just a quick question, which I'm sure the admin are covering with the announcement, but will all posts before the maintenance period be safe?
Also, I know it might be asking how long a bit of string is, but it might be worth giving an estimated time frame.
  • mwc
  • mwc
15 Nov 2026 08:06
Replied by mwc on topic AMSAMOTION IO module
Category: EtherCAT
Thanks for that. I'll have a dig around the github later, as I'm off to do some workshop organising just now.
  • mwc
  • mwc
15 Nov 2026 08:03
Replied by mwc on topic EtherCat homing, limits, and probing
Category: EtherCAT
@tuxcnc for most machines, basic limit/home switch homing is perfectly adequate, especially on stepper driven machines, but on servo driven machines it is pretty common practise to use index homing, however EtherCAT makes that harder to achieve.
There's also the added benefit with closed loop EtherCAT drives (and especially now with the advent of multiturn absolute encoders) that the drives themselves maintain position through power offs, so in drive homing has become a much more beneficial thing to have and use.
Probing to me is the more interesting part. I have a homebuilt CMM, which I currently have no plans to upgrade as it does everything I need it to, so this more a discussion around what could be possible, and when I get around to retrofitting my little mill, I'll want accurate probing on it.
My CMM is stepper driven, with the loop closed using glass scales, and it all driven and controlled with a Dynomotion KFlop and Mach3 using the ProbeIt plugin. The exact trigger point is stored in the KFlop, then transferred to Mach3, eliminating any delays in Mach3 recognising the trigger.
@rodw I know you mention the methods being inherited from Mach3, but Mach3 can handle various probing methods. I know in ProbeIt, you can rely on simply the first touch, slow second touch, or reverse off for storing the touch point.
As a general comment, I'm well aware of chasing pointless accuracies.
The current plasma build, I'd be happy with a 1mm accuracy, as plasma isn't exactly a precision process, however on the two lathes I've previously retrofitted (both of which are now sold, as I have a commercial lathe with standalone controller), accurate X-axis homing made a big difference.
First lathe used a simple optical slot, which had 0.02mm repeatability, but there was noticeable drift with temperature, so if doing anything requiring high accuracy, I had to do a couple test cuts first, whereas the second lathe used servo index homing, and was always spot on.
  • rodw
  • rodw's Avatar
15 Nov 2026 06:01
Replied by rodw on topic AMSAMOTION IO module
Category: EtherCAT
Using the EL6021 is probably the way to go, Once installed, it presents a TTY port that you can use with MB2HAL.
Also the CATIO-A IO module on AliExpress  does Modbus RTU and I have got it going too.
  • rodw
  • rodw's Avatar
15 Nov 2026 05:55
Replied by rodw on topic EtherCat homing, limits, and probing
Category: EtherCAT
I think homing is useful particularly where torque mode homing without any switches as on that said plasma, there is added simplicity engineered in by deleting limit and home switches. Limit switchers are part of some homing methods so if you do homing, you might as well use limits as well.
Probing to me  is  not useful in CNC but maybe for industrial applications. Applications like QTDragon and probe basic do not leverage the full capability of Linuxcnc homing because they don't probe onto a part and then probe away from it. Instead they repeat a probe at a slower angle.
From memory a 3d probe I had said not to exceed 200 mm/min dso something like this is how we should do ut
g38.2 Z -100 F200
g38.5 Z 5 F100 (or F50 even)
F100 = 0.00166 mm per servo period so surely that is as accurate as you need surely
The advantage of this is it removes any spring from the probe and gets a very accurate position much faster than the methods currently In use which seem to have been inherited from Mach3
  • Kittifix
  • Kittifix
15 Nov 2026 04:35
Ethercat installation from repositories - how to step by step
Category: EtherCAT
update to PREEMPT_RT Debian 6.12.117-1 and it works ....
  • tuxcnc
  • tuxcnc
15 Nov 2026 03:41
Replied by tuxcnc on topic EtherCat homing, limits, and probing
Category: EtherCAT
In most machines and their applications, using internal homing within the drive systems makes no sense and offers no benefits.
While it might technically provide greater precision, the question is whether that precision can actually be put to practical use. In amateur-grade machines, certainly not—and even in professional-grade equipment, not necessarily.
For instance, what is the point of homing a plasma cutter to an accuracy of 0.001 mm?
When turning or milling from raw stock, the machining allowance provided is far greater than the precision of the homing process.
Even when performing an additional operation on a nearly finished part—such as reaming a hole—you should still set your zero point using a probe or dial indicator; otherwise, a tiny speck of debris on the vise could ruin the entire job.
  • elizacommunities
  • elizacommunities
15 Nov 2026 02:40
Replied by elizacommunities on topic EtherCat homing, limits, and probing
Category: EtherCAT
Thanks for raising this, it is a useful question. On limits, I would keep LinuxCNC in control of the limit handling where possible, so the behaviour stays consistent across the axes, and treat the drive's internal stop as a safety net rather than the main mechanism. For probing, the drive's internal latch sounds attractive for accuracy, but as you say it adds wiring and configuration for every drive, so for most work probing a little more slowly through LinuxCNC seems the simpler and more maintainable route. I have not used in-drive homing yet, so I would be interested to hear how it behaves in practice once the new release is out.
  • awallin
  • awallin
15 Nov 2026 01:26
Replied by awallin on topic Tuning Steperonline A6 Servos
Category: EtherCAT
the edited parameters can be permanently saved to the drive EEPROM with this command. The -p parameters sets ethercat device number (adjust for your setup, and run this for all drives tuned).
$ ethercat download -p 5 0x1010 1 0x73617665 --type uint32
  • awallin
  • awallin
15 Nov 2026 01:09
Technical questions about CIA402 and homecomp.comp on A6
Category: EtherCAT
FWIW with the latest homecomp updates (github.com/linuxcnc-ethercat/cia402_homecomp/pull/4) I now got cia402 homing working with stepperonline A6 drives.
My config is here github.com/aewallin/FS4MG_config
  • Sviper
  • Sviper
15 Nov 2026 00:41 - 15 Nov 2026 00:44
LCNC-Cyclo: Conversational Programming for LinuxCNC
Category: Other User Interfaces
I'm currently working on LCNC-Cyclo, a shop-floor-oriented user interface for LinuxCNC. The idea: anyone who works with conversational-programming controls at their job should be able to work the same way on their own LinuxCNC mill at home. You write the program in conversational format, call a cycle, fill in the parameters in a form, and you're done.What already works:
  • All screen areas and operating modes you'd expect from a shop-floor control, light/dark theme
  • 58 cycles: drilling, threading, pockets, SL/contour pockets, engraving … each with an input form and help graphic
  • Conversational code is translated live into real LinuxCNC G-code, with a switchable view
  • PLANE functions using LinuxCNC's tilted work plane (G68.2)
  • Simulation with toolpath lines, material removal, full machine model and target/actual comparison against STL
  • Checks for limit switches, rapid moves in material, holder collisions and head/table collisions
  • Sim machines: 4-axis XYZ+B swivel head (my Slayer_1000) and 5-axis XYZAC
    Important: Unmodified LinuxCNC runs underneath. Only G-code is executed on the machine. No third-party software or data is included. The goal is simply to make operation easier for everyone who is used to conversational programming.Next steps: First use on the real machine (EtherCAT, lean system that boots directly into the GUI) and connecting an original matrix keyboard via Arduino.Feedback and ideas are welcome!
    There's still a lot to do, test and expand before this becomes a full-featured GUI, but the first tests on the machine look good.The screenshots are numbered in the order they appear in the text:
    1. Cycle with input form
    2. G-code view
    3. Material removal simulation
    4. Machine simulation
    5. Programming run → Program run
  • Hakan
  • Hakan
14 Nov 2026 23:46
Replied by Hakan on topic AMSAMOTION IO module
Category: EtherCAT
I can give you a pointer. There was recently a commit in linuxcnc-ethercat for EL6021 a serial-over ethercat device.
That should do the Modbus transport.
Displaying 121 - 135 out of 11270 results.
Time to create page: 0.265 seconds
