  • foam man
  • foam man
14 Jul 2026 13:29
Replied by foam man on topic linking U axis to X
linking U axis to X
sorry, I posted on that one, but when nobody replied, I figured the post was too old and wasn't active anymore
  • Mr. Mass
  • Mr. Mass's Avatar
14 Jul 2026 12:58
Replied by Mr. Mass on topic Control panel
Control panel
Category: Show Your Stuff
Ha, that's spot on—I really did feel like a detective sometimes
The top part is a standard PS/2 keyboard; I connected it to the computer using a PS/2-USB adapter. I remapped the keys, mainly to access lowercase characters (Remap the Shift + button, just like in the original system).
The lower part is connected via an Arduino and an ArduinoConnector (forum.linuxcnc.org/show-your-stuff/48630-arduino-io-expansion).
On this keyboard, the pinout is rotated 90 degrees relative to the visual orientation, and not all pins are used. I added a pinout; I hope this helps.
P.S. The SK6 keyboard has a visually different circuit board; I haven't checked it, so all of this applies only to the SK4.
  • RoberCNC
  • RoberCNC
14 Jul 2026 09:18
Replied by RoberCNC on topic Problem with PROBE tab after running a program
Category: Qtvcp
Hi Chris.
Here you have the file.
  • Ismacr63
  • Ismacr63
14 Jul 2026 07:51
Replied by Ismacr63 on topic Probe Basic widgets missing
Category: QtPyVCP
Now it has let me set it to 5 + Jog, and it displays correctly.
  • Ismacr63
  • Ismacr63
14 Jul 2026 07:47
Replied by Ismacr63 on topic calling all probe basic lathe users!
Category: QtPyVCP
Sweet are you in the probe basic Facebook group?
Yes, I'm in the Facebook group.
  • BlownCorona
  • BlownCorona
14 Jul 2026 07:27
Replied by BlownCorona on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
Category: Installing LinuxCNC
Heh.. the very next search i did after replying lead me to the info that the displaylink driver doesn't handle touch, Linux kernals hud-multitouch does.
always something new to learn eh.. though its pretty obveous in hindsight
  • BlownCorona
  • BlownCorona
14 Jul 2026 07:18 - 14 Jul 2026 07:23
To be fair to Tommy, I've used this ISO successfully for a while now, this is the first issue I've come across and its not anything to do with linuxcnc, and sounds like I can resolve it.
In fact the synaptics displaylink drivers are only officially offered for ubuntu, while there is a community Debian option available, and the second computer I have that I set up a Debian build on is struggling to get the screen to show anything, where as this Mint ISO already allows the screen to display and operate with single point touch only, which would actually be sufficient for a cnc mill, but less refined than the screen could be.
This goes to show that there are pros and cons to all options and its not at all accurate to claim we must stick with Debian.
With that said, i am wanting to try Probe Basic, and being that this was developed for Debian may be the way i go, hence the aforementioned debian unit.
To all that replied with useful information, greatly appreciated. Ill report back with results.
  • cmorley
  • cmorley
14 Jul 2026 06:17
Category: Qtvcp
well strange.
If you are content to just ignore the warning that's fine, otherwise I would need you to find the qtdragon_hd_handler.py file from your system so i could see why it's different.
  • Lcvette
  • Lcvette's Avatar
14 Jul 2026 05:07
Replied by Lcvette on topic calling all probe basic lathe users!
Category: QtPyVCP
  • Lcvette
  • Lcvette's Avatar
14 Jul 2026 05:06
Replied by Lcvette on topic Probe Basic widgets missing
Category: QtPyVCP
Lathe was always laid out for 4 + jog and Mill for 3+ jog for best fitment, if you had 7 i can't imagine it looked very good, probably all smooshed up with no space. We fixed some formatting issues and that one was one I think where it wouldn't smoosh them together. But not it pushes the screen off the bottom.. so we are to the docs a recommended limit count.
14 Jul 2026 01:01
Very small 4 axis mill for cutting plastic materials
OK, just got back from the shop, and we have results, pretty good ones, now i think i have to mess with some TCP parameters as some moves are not where they should be, but in general it seems it works, it is much better than any of my attempts to coerce Gemini.
Almost 3AM here, going to watch "A Brief History of Exploring Mars" by "Classic Aerospace History" on youtube, and maybe sleep.
Was a good day, finished a lot of things on a cnc router till 9PM, ate, went for a coffee, came back to this.
Been quite some time since i had such productive day, missed it... :)
Aciera, thank you.
  • onceloved
  • onceloved's Avatar
13 Jul 2026 21:43
Every time I boot LinuxCNC, the Xg54 position reading increase 256
ini配置中注释或删除这行试试POSITION_FILE = position.txt
具体作用http://linuxcnc.org/docs/stable/html/config/ini-config.html#sub:ini:sec:traj
  • Ismacr63
  • Ismacr63
13 Jul 2026 21:01
Category: QtPyVCP
As you probably know, I’ve been using Probe Basic Lathe for quite some time on a 200x400 mini-lathe.
  • Ismacr63
  • Ismacr63
13 Jul 2026 20:59
Category: QtPyVCP
Solved! In the old configuration, I had those 7 increments and it displayed correctly. I'm not sure if it's something related to the Trixie version. Thanks a lot!
  • Ismacr63
  • Ismacr63
13 Jul 2026 20:23
Bearing replacement advice for PM-25MV mill (spindle and pulley shaft)
Category: Milling Machines
I'm about to replace the bearings in my PM-25MV style mill. I've got a 1.8kW AC servo motor on the spindle that runs up to 4500 rpm.
Two questions:
For the bearings on the pulley shaft (the intermediate shaft that drives the spindle belt), should I go with C3 clearance or standard clearance?
What tapered roller bearings would you recommend for the spindle itself?
Any advice from people who've already done this would be great. Thanks!
Displaying 1741 - 1755 out of 13507 results.
Time to create page: 0.206 seconds
