keyboard shortcut
- Ismacr63
- Thank you received: 11
28 Jan 2026 22:12 #342106
by Ismacr63
keyboard shortcut was created by Ismacr63
I’ve been using Probe Basic for a while, and I was wondering if it’s possible to assign keyboard shortcuts to turn the spindle on and off.
- Lcvette
- Thank you received: 784
02 Feb 2026 01:38 - 02 Feb 2026 15:58 #342304
by Lcvette
Replied by Lcvette on topic keyboard shortcut
Probably, but I'm not sure what the best way to do it would be. I really hate using the keyboard for things like that because it can be dangerous under some conditions. I use a touch screen and it's easy the way the ui is setup to just use the on screen controls for that type scenario. the risk of accidentally turning something like the spindle on while typing scares the crap out of me. The focus of the ui components can alter keyboard behavior so if you think your in a lineedit but focus is somewhere else in the ui you could easily trigger the spindle inadvertantly. How many times have you typed something only to look up and see no text in the box because I had not set focus on the entry when I thought I had. Bad scary..lol
Last edit: 02 Feb 2026 15:58 by Lcvette.
The following user(s) said Thank You: NWE
- Ismacr63
02 Feb 2026 09:48 #342310
by Ismacr63
Replied by Ismacr63 on topic keyboard shortcut
Yes, I completely agree, it could be more dangerous than practical. Do you think any alternative would be to install a physical button on one of the ports to activate the spindle?
I have a parallel port with all the ports occupied. Would it be possible to configure the parallel port in "in" or "x" mode to have more ports?
- Thank you received: 7487
02 Feb 2026 13:50 #342315
And you can not get more ports, the limit is 17, but you can choose between more inputs or more outputs:
OUT = 12 out 5 in
IN = 4 out 13 in
X = 8 out 9 in
Be aware that pins 1,14,16,17 require more current to trigger when set as inputs.
Replied by tommylight on topic keyboard shortcut
The only way to know for sure is to test it, most will work, but some will not.Would it be possible to configure the parallel port in "in" or "x" mode to have more ports?
OUT = 12 out 5 in
IN = 4 out 13 in
X = 8 out 9 in
The following user(s) said Thank You: Ismacr63
- Thank you received: 4149
04 Feb 2026 05:20 #342361
Replied by rodw on topic keyboard shortcut
you might be able to use a USB modbus interface (serial to rs485)
- Ismacr63
06 Feb 2026 14:47 #342548
by Ismacr63
I was thinking that the best option would be to use an MPG WHB04B? Is the wireless or wired version better? Can everything be controlled from the MPG, including the start/stop spindle?
- Lcvette
06 Feb 2026 20:07 #342567
by Lcvette
depending on the type f mpg it is possible. some usb mpg versions require some conflict resolution in the postgui hal but its not too bad.
- Ismacr63
06 Feb 2026 20:54 #342568
by Ismacr63
Do you think the MPG XHC WHB04B 4 model will work well?
Wireless, wired, or does it not matter?
- Lcvette
06 Feb 2026 21:23 #342572
by Lcvette
i hve not used it before, but i think others have.. you will need to pay attention to the timer function in the postgui hal file and i think maybe something else in there but i don't remember. im sure someone using it can better directly assist with whats needed or a search in here may bring something up.
Moderators: KCJ, Lcvette
Time to create page: 0.275 seconds
