G0 Moves all axis at once
11 Jan 2020 18:17 #154628 by JB-Motoring
G0 Moves all axis at once was created by JB-Motoring
Hey guys,
I've played around with my pp- but i didn't make a safe copy before doing that....
Now I've downloaded the actual Linuxcnc PP from HSM.
Before every G0 Move started with g53 Z0- So that the tool was always all the way up in Z.
Now the PP moves all 4 Axis at once- thats way too criminal with the fourth axis mounted along X.
How can I change that? SO that it first moves G53 G0 Z0 Then G0 XYA??
Thanks guys !
12 Jan 2020 03:01 #154659 by Shu
Replied by Shu on topic G0 Moves all axis at once
The standard LinuxCNC PP works well. Why did you load another one? Anyways, you would need to change that in the PP file.
If you can't find the right spot, compare it with the standard PP that is shipped with Fusion (because that one does move correctly). Or any other standard one (e.g. Fanuc).
Time to create page: 0.061 seconds
