2-axis mill
13 Apr 2020 01:31 #163833 by Doug Crews
2-axis mill was created by Doug Crews
Hello, I have x&y working good on my mill, but I need to machine some parts before I can get Z-axis going. Does anyone have or can point me to a 2-axis post processor for Fusion 360?
Thanks!
13 Apr 2020 08:41 #163851 by bbsr_5a
Replied by bbsr_5a on topic 2-axis mill
why dont you simply remove all Z moves with a Editor
shoudt be only 2 Klicks
or as you do not have Z axis in Real just run the g-code and no axis is moving at all on Z command while the Graphics displays z
13 Apr 2020 14:49 #163877 by Doug Crews
Replied by Doug Crews on topic 2-axis mill
Yes thanks, That's what I've been doing. It works but I'm realizing that 2axis is most of the work that will be done on this machine. The machine is a knee mill where the knee is the Z-axis. I'm keeping the quill as is to run by hand. It's used for tooling and one off parts. Basically, I've copied the Trak mill. Late last night found a fusion 360 post-processor for the Trak mill with a manual Z-axis. It's very cool, if it encounters a z-move it pauses the program and prompts you to move the z-axis by the programmed amount. It needs to be tweaked for EMC though. I'll probably need some help with that.
Time to create page: 0.332 seconds
